Userform change event not working when linked from another userform.
Question asked by Sam Molony on Mar 3, 2017
Latest reply on Mar 6, 2017 by Sam Molony
I have 2 userforms, when the first (userform1) links to the second (userform6), the change event in the second will not activate.
The strange thing is, if I run the second userform directly, all of the code executes perfectly.
Anyone know of anything which can cause this?
Part of userform1:
Private Sub userform_initialize()
MatVal.AddItem ("303 Stainless Steel")
MatVal.AddItem ("416 Stainless Steel")
BuildButton.Enabled = False
Private Sub TDVal_change()
RemoveChar = 1
If Not IsNumeric(UserForm1.TDVal.Value) And Len(UserForm1.TDVal) <> 0 Then
    If Len(UserForm1.TDVal) < 1 Then RemoveChar = 0
    UserForm1.TDVal = Left(UserForm1.TDVal, Len(UserForm1.TDVal) - RemoveChar)
    UserForm1.Hide
    UserForm6.Show     LINKS HERE
If MatVal.Text <> "Select Material" And TDVal <> "" And SLVal <> "" And (EngBox = True Or MarkBox = True) Then
    BuildButton.Enabled = True
Else
Part of userform6:
BuyButton.Enabled = False
Private Sub Acc_change()  (SUB DOESN'T ACTIVATE)
RemoveChar = 1
If Not IsNumeric(UserForm6.Acc.Value) And Len(UserForm6.Acc) <> 0 Or Len(UserForm6.Acc) > 8 Then
    If Len(UserForm6.Acc) < 1 Then RemoveChar = 0
    UserForm6.Acc = Left(UserForm6.Acc, Len(UserForm6.Acc) - RemoveChar)
    UserForm6.Repaint
If IsNumeric(UserForm6.Acc.Value) And Len(UserForm6.Acc) = 8 And IsNumeric(UserForm6.Sort1.Value) And Len(UserForm6.Sort1) = 2 And IsNumeric(UserForm6.Sort2.Value) And Len(UserForm6.Sort2) = 2 And IsNumeric(UserForm6.sort3.Value) And Len(UserForm6.sort3) = 2 And IsNumeric(UserForm6.Sec.Value) And Len(UserForm6.Sec) = 3 Then
    BuyButton.Enabled = True
    Else
Any ideas?
Cheers
