1 Reply Latest reply on Mar 3, 2017 12:25 PM by Patrik MacHalec
    Component2.GetVisibility returns -1
    Jana Stahn
      Sometimes when I call
      IComponent2.GetVisibility(3, new string[] { "configName" })[0]
      ( it gets the visibility state of the component in configuration "configName")
      I get the return value -1.
      What does it mean? There is no -1 listed in the documentation of the visibility values (swComponentVisibilityState_e Enumeration).
      And when does it happen?
      I have an assembly where the component that gives visibility -1...
      - ...is a top level component
      - ...is not suppressed
      - ...has a real name, i.e. not "".
      - ...has a real ID (get it via IComponent2.GetID()), i.e. the ID is not -1.
      Unfortunately I cannot attach the model since it is owned by a customer.
      Is there anyone who experienced this behaviour or knows something about this?
        • Re: Component2.GetVisibility returns -1
          Patrik MacHalec
          Hi Jana,
          another reason why you got value -1 is that configuration of component was renamed or deleted.
          If you use (int)swInConfigurationOpts_e.swThisConfiguration instead of (int)swInConfigurationOpts_e.swSpecifyConfiguration it should work. I assume that you have a reason to use "swSpecifyConfiguration".
          I do not have knowledge how to solve it.
