Re: Convert Decimal value to Fractions
Peter Brinkhuis Mar 3, 2017 8:24 AM (in response to JOHN GEORGE)The function should return a string according to the first line. In the code you set the function name to a certain value to return that value. In line 30 to 37 the string DecimalToFeetInches is being set, so this part:
DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-"
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches))
If intFractions > 0 Then
DecimalToFeetInches = DecimalToFeetInches & "-"
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions))
DecimalToFeetInches = DecimalToFeetInches & "/" & LTrim$(Str$(Denominator))
DecimalToFeetInches = DecimalToFeetInches & Chr$(34)
The first line is this section (line 30 in the original) prints the first section, the number of feet, a quote and a dash. You can make this optional with an if statement:
If IntFeet <> 0 Then
This might give you problems when the next line concatenates an empty string with other text, but VBA isn't very strict so it'll probably work. If it doesn't, initialize the string to "" at the declaration.
JOHN GEORGE Mar 3, 2017 4:06 PM (in response to Peter Brinkhuis)Peter,
Thanks for your help and really appreciate your suggestion
Just another thought.. Is it possible to return the result without the 0 in 0-63/64 (my mistake in my first post)
Same as feet, if the value is less than 1 inch, it should show only 63/64"
Peter Brinkhuis Mar 3, 2017 5:11 PM (in response to JOHN GEORGE)I'll help you one more time, if you promise me you'll stop using freedom units in the near future
Function DecimalToFeetInches(DecimalLength As Variant, Denominator As Integer) As String ' converts decimal inches to feet/inches/fractions Dim intFeet As Integer Dim intInches As Integer Dim intFractions As Integer Dim FractToDecimal As Double Dim remainder As Double Dim tmpVal As Double ' compute whole feet intFeet = Int(DecimalLength / 12) remainder = DecimalLength - (intFeet * 12) tmpVal = CDbl(Denominator) intInches = Int(remainder) remainder = remainder - intInches If Not (remainder = 0) Then If Not (Denominator = 0) Then FractToDecimal = 1 / tmpVal If FractToDecimal > 0 Then intFractions = Int(remainder / FractToDecimal) If (remainder / FractToDecimal) - intFractions > 0 Then intFractions = intFractions + 1 End If End If End If End If Call FractUp(intFeet, intInches, intFractions, Denominator) ' Simplify up & down If intFeet <> 0 Then DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-" End If If (DecimalToFeetInches <> "" Or intInches <> 0) Then DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches)) If intFractions <> 0 Then DecimalToFeetInches = DecimalToFeetInches & "-" End If End If If intFractions > 0 Then DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions)) DecimalToFeetInches = DecimalToFeetInches & "/" & LTrim$(Str$(Denominator)) End If DecimalToFeetInches = DecimalToFeetInches & Chr$(34) End Function
JOHN GEORGE Mar 3, 2017 5:24 PM (in response to Peter Brinkhuis)Thanks Peter,
Sure.. I will stop using units and use only fractions..
Elmar Klammer Mar 3, 2017 6:14 PM (in response to JOHN GEORGE)Download the excel workbook from link below. The module Josh has put together works very well. Good learning tool as well.
Below the formula to round to 1/16" using the Josh's i2s function. Change 0.0625 to 1/X (X being the rounding tolerance . In this case 1/16 = 0.0625) If you want 1/8 replace with 0.125. Fractions have never been easier. Great tool
0.6 0'-0 5/8" i2s(SUBSTITUTE(MROUND(A1,0.0625),CHAR(34),""),1)
