Is it possible to stop SW moving parts in every direction apart from the direction required by the mate? We are finding that SW is putting parts inside other parts. For instance, trying to mate a PCB with a milled box, the PCB will disappear into the solid metal of the box. The only way to see it again is to select it in the FeatureManager and use the Move Component command. I've had a look through the options and can't find anything.
Change this setting
