I pretty much never use sheet metal, but here's this Part that I modeled this morning, and the client is asking for a flat pattern. Would someone mind taking a look at it and see if it can be easily converted? I wouldn't expect anyone to spend much time on it, but I'm hoping it's fairly simple using the "Convert to Sheet Metal" command. I tried, but don't know what inputs are needed to make the command work. It's one body of a multi-body Part, and I'm afraid I can't post the rest due to the client's proprietary concerns.
I'd appreciate any help,
Glenn
Start out with the sheet metal loft feature. You cannot convert your solid to sheet metal since it is a loft.
