7 Replies Latest reply on Jul 2, 2017 5:51 AM by Yong Ning
    How to determine the vertical size, or horizontal size.
    Yong Ning
      follow code, don't determine oriate.
      Private Sub ll1()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
             Set SwApp = Application.SldWorks
             Set SwModel = SwApp.ActiveDoc
         Dim SwSelMgr As SelectionMgr
             Set SwSelMgr = SwModel.SelectionManager
         Dim SwDispDim As DisplayDimension, SwDim As Dimension
         Dim SwAnn As Annotation
             Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
             With SwDispDim
                 Debug.Print .VerticalJustification, .HorizontalJustification
                 Set SwDim = .GetDimension
                 Set SwAnn = .GetAnnotation
                 Set Ss = SwDim.ExtensionLineDirection
             End With
             SwModel.ForceRebuild3 True
      Get Display Dimension Type - API | SOLIDWORKS Forums  https://forum.solidworks.com/message/317119#comment-317119
        • Re: How to determine the vertical size, or horizontal size.
          Viktor Bovzdarenko
          Hi Yong,
          VerticalJustification and HorizontalJustification are related to text inside the dimension. These properties do not tell if the dimension is horizontal or vertical.
          Try to use: value = IDisplayDimension.Type2
          the value will give more info about the dimension itself.
          swDimensionType_e
          swHorLinearDimension11 = Horizontal linear dimension
          swHorOrdinateDimension7 = Horizontal ordinate dimension
          swLinearDimension2 = Linear dimension type
          swOrdinateDimension1 = Base ordinate and its subordinates are of this type
          swRadialDimension5 = Radial dimension
          swScalarDimension13
          swVertLinearDimension12 = Vertical linear dimension
          Regards
          Viktor
              Yong Ning
              Thank your replay post.
              in Smart Dimenstin,  Type2 is 2
              Private Sub ll1()
                 Dim SwAnn As Annotation, SwLine As SketchLine, Sw As SketchSegment
                     With SwDispDim
                         Debug.Print .Type2  ' → result is 2
                     End With
                  Viktor Bovzdarenko
                  Hi Yong,
                  then maybe you can try to get the vector for dimension? see the example:
                      Dim SwDispDim As DisplayDimension: Set SwDispDim = SwModel.SelectionManager.GetSelectedObject5(1)
                      Dim SwDim As Dimension: Set SwDim = SwDispDim.GetDimension2(0)
                      Dim SwDimVector As MathVector: Set SwDimVector = SwDim.DimensionLineDirection
                      Debug.Print SwDimVector.ArrayData(0) & " : " & SwDimVector.ArrayData(1) & " : " & SwDimVector.ArrayData(2)
                  For horizontal dimension I got: X = 1 Y = 0 Z = 0
                  vertical : X = 0 Y = 1 Z = 0
                      Yong Ning
                      Thank you reply, with the DimensionLineDirection method, to determine the direction
                      Function DimLineDirect(SwDispDim As DisplayDimension)
                               Debug.Print SwDim.FullName, SwDim.Value
                               Debug.Print "    Manipulating MathVector → " & _
                      End Function
                      Private Sub ll()
                           Dim SwDraw As DrawingDoc
                               Set SwDraw = SwModel
                           Dim SwView As View, SwDispDim As DisplayDimension
                               Set SwView = SwDraw.GetFirstView
                               Do While Not SwView Is Nothing
                                   Set SwDispDim = SwView.GetFirstDisplayDimension
                                   Do While Not SwDispDim Is Nothing
                                       Debug.Print SwView.Name,
                                       DimLineDirect SwDispDim
                                       Set SwDispDim = SwDispDim.GetNext
                                   Loop
                                   Set SwView = SwView.GetNextView
                               Loop
                      Result is
                      鞍座F主视图   Delta4@Sketch@垫板.Part      8
                          Manipulating MathVector → .902678611255778 : -.430315378276608 : 0
                      鞍座F主视图   D1@h@鞍座F.Assembly          200
                          Manipulating MathVector → 0 : -1 : 0
                      鞍座F主视图   ArcLen@Sketch@垫板.Part      1180
                          Manipulating MathVector → 0 : 0 : 0
                      鞍座F主视图   ShellR@Sketch@垫板.Part      524
                      鞍座F左视图   D1@b4@垫板.Part              350
                          Manipulating MathVector → 0 : 0 : 1
                      鞍座F左视图   D1@e@垫板.Part               70
                          Manipulating MathVector → 0 : 0 : -1
                      Section View A2-A2          l1@Sketch@底板F.Part         760
                          Manipulating MathVector → 1 : 0 : -3.65204942310907E-17
                      Section View A2-A2          b1@Sketch@底板F.Part         170
                      Section View A2-A2          cutD@Sketch@底板F.Part       24
                      Section View A2-A2          l2@Sketch@底板F.Part         600
                          Manipulating MathVector → -1 : 0 : 0
                      2012 SOLIDWORKS API Help - Get Extension Line Direction Example (VBA)  http://help.solidworks.com/2012/english/api/sldworksapi/get_extension_line_direction_example_vb.htm
                      Dim SwModel                 As SldWorks.ModelDoc2
                      Dim SwDraw                  As SldWorks.DrawingDoc
                      Dim SwView                  As SldWorks.View
                      Dim SwDispDim               As SldWorks.DisplayDimension
                      Dim SwDim                   As SldWorks.Dimension
                      Dim SwAnn                   As SldWorks.Annotation
                      Dim swDisplayDimension      As SldWorks.DisplayDimension
                              Set SwAnn = SwView.GetFirstAnnotation3
                              While Not SwAnn Is Nothing
                                  Debug.Print " "
                                  Debug.Print "Annotation name = " & SwAnn.GetName
                                  If SwAnn.GetType = swAnnotationType_e.swDisplayDimension Then
                                      Debug.Print "  Is a display dimension? True"
                                      Set swDisplayDimension = SwAnn.GetSpecificAnnotation
                                      Select Case (swDisplayDimension.Type2)
                                         Case swDimensionType_e.swOrdinateDimension
                      Debug.Print "  Display dimension type = " & GetOrientation(swDisplayDimension) & " ordinate and its subordinates"
                                         Case swDimensionType_e.swLinearDimension
                      Debug.Print "  Display dimension type = " & GetOrientation(swDisplayDimension) & " linear"
                                         Case swDimensionType_e.swAngularDimension
                      Debug.Print "  Display dimension type  = angular"
                                         Case swDimensionType_e.swArcLengthDimension
                      Debug.Print "  Display dimension type = arc length"
                                         Case swDimensionType_e.swRadialDimension
                      Debug.Print "  Display dimension type = radial"
                                         Case swDimensionType_e.swDiameterDimension
                      Debug.Print "  Display dimension type = diameter"
                                         Case swDimensionType_e.swHorOrdinateDimension
                      Debug.Print "  Display dimension type = horizontal ordinate"
                                         Case swDimensionType_e.swVertOrdinateDimension
                      Debug.Print "  Display dimension type = vertical ordinate"
                                         Case swDimensionType_e.swZAxisDimension
                      Debug.Print "  Display dimension type = z-axis"
                                         Case swDimensionType_e.swChamferDimension
                      Debug.Print "  Display dimension type = chamfer dimension"
                                         Case swDimensionType_e.swHorLinearDimension
                      Debug.Print "  Display dimension type = horizontal linear"
                                         Case swDimensionType_e.swVertLinearDimension
                      Debug.Print "  Display dimension type = vertical linear"
                                         Case swDimensionType_e.swScalarDimension
                      Debug.Print "  Display dimension type = scalar"
                                         Case Else
                      Debug.Print "  Display dimension type = unknown"
                                      End Select
                                  Set SwAnn = SwAnn.GetNext3
                              Wend
                          Wend
                      Function GetOrientation(swDisplayDimension As DisplayDimension) As String
                          Set SwDim = swDisplayDimension.GetDimension '2(0)
                          Dim swMathVec As SldWorks.MathVector
                          Dim vDir As Variant
                          GetOrientation = ""
                          Set swMathVec = SwDim.DimensionLineDirection
                          vDir = swMathVec.ArrayData
                          If IsCollinear(vDir(0), 1) And IsCollinear(vDir(1), 0) Then
                              GetOrientation = "horizontal"
                          ElseIf IsCollinear(vDir(1), 1) And IsCollinear(vDir(0), 0) Then
                              GetOrientation = "vertical"
                      End Function
                      Function IsCollinear(val As Variant, vector As Double) As Boolean
                          Const TOL = 0.00000001
                          IsCollinear = Abs(Abs(val) - Abs(vector)) < TOL
                      End Function
                          Yong Ning
                              Dim vDir As Variant
                              GetOrientation = ""
                                  GetOrientation = "HOR"
                                  GetOrientation = "VER"
                          End Function
                          End Function
                          Function DispDimType(SwDispDim As DisplayDimension)
                                    Select Case SwDispDim.Type2
                                                   Debug.Print "" & GetOrientation(SwDispDim) & " ordinate and its subordinates"
                                                   Debug.Print "" & GetOrientation(SwDispDim) & " linear"
                                                   Debug.Print "arc length"
                                                   Debug.Print "radial"
                                                   Debug.Print "diameter"
                                                   Debug.Print "horizontal ordinate"
                                                   Debug.Print "vertical ordinate"
                                                   Debug.Print "z-axis"
                                                   Debug.Print "chamfer dimension"
                                                   Debug.Print "horizontal linear"
                                                   Debug.Print "vertical linear"
                                                   Debug.Print "scalar"
                                             Case Else
                                                   Debug.Print "unknown"
                                    End Select
                          End Function
                          DisplayDimension::Type2
                          This method gets the type of dimension.
                          retval = DisplayDimension.Type2 (VB Get property)
                          Type of dimension as defined by swDimensionType_e
                          swDimensionType_e
                          swDimensionTypeUnknown - Dimension type could not be determined
                          swOrdinateDimension - Base ordinate and its subordinates are of this type
                          swLinearDimension - Linear dimension type
                          swAngularDimension - Angular dimension type
                          swArcLengthDimension - Arc length dimension type
                          swRadialDimension - Radial and diametric dimensions are of this type
                          swDiameterDimension
                          swHorOrdinateDimension - Horizontal ordinate dimension
                          swVertOrdinateDimension - Vertical ordinate dimension
                          swZAxisDimension
                          swChamferDimension
                          swHorLinearDimension - Horizontal linear dimension
                          swVertLinearDimension - Vertical linear dimension
                          swScalarDimension
                          Yong Ning
                          [cos0,    -sin0,   x0-(cos0*x0 - sin0*y0)]
                          [sin0,     cos0,   y0-(sin0*x0 + cos0*y0)]
                          [   0,        0,                       1 ]
                          3x3 Matrix Rotation in C++ - Stack Overflow  https://stackoverflow.com/questions/16663647/3x3-matrix-rotation-in-c?noredirect=1
                          Function HorVerArr(SwModel As ModelDoc2, SwMathUtil As MathUtility, SwView As View, SwDispDim As DisplayDimension)
                             Dim SwXForm As MathTransform
                                 Set SwXForm = SwView.ModelToViewTransform
                             Dim SwAnn As Annotation, SwAnn1 As Annotation
                             Dim Ss, oScale, ii, Str
                             Dim MathPt As MathPoint
                             Dim SwNote As Note
                                 With SwDispDim
                                     'Debug.Print SwDim.FullName
                                     Ss = SwDim.ReferencePoints
                                     oScale = 1
                                     For ii = 0 To 2
                                         Set MathPt = Ss(ii)
                                         Set MathPt = MathPt.MultiplyTransform(SwXForm)
                                         With MathPt
                                                  Debug.Print "   xy(" & ii & "," & 0 & ")=" & Round(.ArrayData(0), 6) & ":",
                                                  Debug.Print "   xy(" & ii & "," & 1 & ")=" & Round(.ArrayData(1), 6)
                                                  tmp = SwModel.Extension.SelectByID2("", "VERTEX", .ArrayData(0), .ArrayData(1), .ArrayData(2), False, 0, Nothing, 0)
                                                  Str = SwDim.Name & "-" & ii
                                                  Str = Str & vbCr & " (" & Round(.ArrayData(0), 4) & "," & Round(.ArrayData(1), 4) & ",0)"
                                         End With
                                     Next ii
                                 End With
                             Dim MathVext As MathVector, Pt(2) As Double
                                 Set MathVect = SwDim.DimensionLineDirection
                                 vDir = MathVect.ArrayData
                                 Str = "("
                                 For jj = 0 To 2
                                      Str = Str & Round(vDir(jj), 5) & ","
                                 Next jj               ''
                                 Str = Left(Str, Len(Str) - 1) & ")" & vbCrLf
                                 Str = Str & GetOrientation(SwDispDim) & "-" & SwDim.Name
                                 SwAnn.Select True
                                 SwModel.EditDimensionProperties2 0, 0, 0, "", "", 1, 9, 2, 1, 11, 11, "", "", 1, "", Str, 1
                                 'SwModel.GraphicsRedraw2
                          End Function
                          Private Sub SheetDimensionHorVer()
                              Dim SwMathUtil As MathUtility
                                   Set SwMathUtil = SwApp.GetMathUtility
                              Dim vSheets, SwSheet As Sheet
                              Dim SwView As View
                              Dim SkSketch As Sketch, SkPtArr
                              Dim SwNote As Note, SwAnn As Annotation, Anns
                                   vSheets = SwDraw.GetSheetNames
                                   For ii = UBound(vSheets) To 0 Step -1
                                       SwDraw.ActivateSheet vSheets(ii)
                                       Set SwSheet = SwDraw.GetCurrentSheet
                                       Set SwView = SwDraw.GetFirstView             ''
                                             SwModel.ClearSelection2 True
                                             Set SwNote = SwView.GetFirstNote
                                             Do While Not SwNote Is Nothing
                                                 'Debug.Print SwNote.GetText
                                                 Set SwAnn = SwNote.GetAnnotation
                                                 SwAnn.Select True
                                                 Set SwNote = SwNote.GetNext
                                             Loop
                                             SwModel.EditDelete
                                                 With SwDispDim
                                                     If .Type2 = 2 Or .Type2 = 11 Or .Type2 = 12 Then
                                                         Arr = HorVerArr(SwModel, SwMathUtil, SwView, SwDispDim)
                                                 End With
                                             Loop
                                       Loop
                                   Next ii
                          Viktor Bovzdarenko
                          Please note that sometimes the value of the vector could be negative (e.g. -1 ot +1). But still in both cases the dimension is pointing the same direction
