Can I change dimensions inside a block?
Question asked by J. Connell on Feb 28, 2017
Latest reply on Mar 2, 2017 by Deepak Gupta
Is it possible to have dimensions inside of a block and then adjust them later and have the change cascade through all instances of that block? When I select a dimension in a block I get baloon tip that says "sketch blocks cannot be scaled" and changing the dimension gives the invalid geometry error. I understand that when you are at the sketch level you can't scale a whole block but shouldn't you be able to make dimensional adjustments to geometry inside the block?
Thanks.
