29 Replies Latest reply on Mar 6, 2017 5:41 PM by Jim Steinmeyer
    editing the sheet format
    Zach Worman
      Could someone please tell me how to add the degree symbol to this.   ANGULAR: MACH<MOD-PM> 3 BEND <MOD-PM>
        • Re: editing the sheet format
          Bjorn Hulman
          <MOD-DEG>
            Matthew Lorono
            You can also just use the Symbol Library to insert this and any number of symbols.
            -or-
                Jim Steinmeyer
                Matthew,
                Is it possible for us to add more symbols to this folder? It would be nice to use things like ² ³ which we frequently use. I can easily pull open the character Map for Windows but having them in the Note folder would make it easier.
                Thank you
                    Dan Pihlaja
                    Yes, you can.
                    Although you essentially have to draw them.
                    http://www.design-point.com/symbol-library-custom-symbols/
                    You will find your gtol.sym file in this location:
                    What S. Casale said, too.
                        Jim Steinmeyer
                        Scott and Dan,
                        Although maybe Matthew Lorono might be more able to answer this. That was good information you provided. The author indicated that nonstandard symbols would not be read on someone else's machine unless the symbols were in their symbol library too. Would this also be true of standard Microsoft symbols in the Character library? I suspect so but it never hurts to ask.
                            Dan Pihlaja
                            The ASCII Character that Glenn Schroeder suggested is a windows thing....(I think).  I don't understand it fully, but I think that in order for the Character library symbols to work across different computers, both computers have to have the same fonts installed.  This normally is not an issue.
                            As for the Symbol in the GTOL file, I believe that both computers have to referencing the same GTOL file (or at least have a file with the same symbol defined in it).
                            So, you can put a copy of the GTOL file on the network and reference the same file for all users byu modifying this location for all users:
                            Also, the symbol that is created in the Symbol folder is not quite the same as the symbol that is created by the ASCII (although I am sure that it gets the job done).  However, since they are not the same, you might want to make sure that the same method is used throughout the drawing (some people are anal like that........like me....*grin*)
                                Jim Steinmeyer
                                Dan ,
                                Yes what Glenn  mentioned would be an ASCI Char which I am looking for. We frequently use some of those symbols in our notes for square feet of material or a few other ASCI things that are not in the SW folders. It is fine if you have a memory like Glen's but I used up all of my RAM a few years ago so I like any shortcuts I can find. It would be nice if I could load a sym library on the network and get everyone to use it but I am having enough problems getting them to at least use only a couple different sheet formats rather than one for each person. Guess I will just have to keep the Char Map open for now.
                                    Glenn Schroeder
                                    Jim Steinmeyer wrote:
                                    Dan ,
                                    You're giving me way too much credit.  I have this tacked up to the bulletin board behind my monitor.
                                        Jim Steinmeyer
                                        later I guess.
                                            Matthew Lorono
                                            That's mildly ironic that you are blocked from seeing a method to improve password security.
                                              Dan Pihlaja
                                              Copy/paste from the webpage:
                                              ALT+NUMPAD ASCII Key Combos: The α and Ω of Creating Obscure Passwords
                                                      As some Microsoft Operating System geeks know, you can type many more characters than are on a standard keyboard by using the ALT+NUMPAD combination technique. For example, by holding down the ALT key, typing 234 on the number pad, then releasing ALT gives you the Ω character. I'm writing this article mostly because when I search around for information on the topic of ALT+Number key combos I find pages that are lacking in details. Most of the pages I found are coming from the angle of using ALT+NUMPAD combinations as shortcuts for typing in non-English languages, but I have another use for them. Using ALT+NUMPAD can make for some very ugly passwords to crack. These odd characters have two major advantages over normal keystrokes:
                                              1. They are unlikely to be in someone's dictionary or brute force list. Try brute forcing a password like "ace of ♠s" or "I am the α and the Ω".
                                              2. Some hardware key loggers will not log these odd characters. Your mileage may vary on this as some key loggers can, so don't rely on it to keep you 100% safe.
                                                      I'll cover the 2nd point more in an upcoming article. Using ALT+NUMPAD to type odd characters into your password also has a few disadvantages.
                                              1. The way they are described in this article only works in Microsoft Operating Systems (DOS, Windows 9x, Vista, XP, 2000), and there may be some variation amongst the different versions. If you know of a good way to do the same thing in Linux please email me.
                                              2. Not all applications will let you use these odd characters. For testing I tried the password "Ωÿ" (ALT+234 and ALT+0255) on a Windows XP local account, and on the IP.Boards at  BinRev.com and it worked fine, but not all application will let you use these sorts of characters in your password.
                                              Microsoft has the following to say on the subject of ALT+NUM key codes:
                                              From:http://www.microsoft.com/globaldev/reference/glossary.mspx
                                              Alt+Numpad: A method of entering characters by typing in the character's decimal code with the Numeric Pad keys (Num Lock turned on). In Windows:
                                              • Alt+<xxx>, where xxx is the decimal value of a code point, generates an OEM-encoded character.
                                              • Alt+<0xxx>, where xxx is the decimal value of a code point, generates a Windows-encoded character.
                                              • Alt+<+>+<xxxx>, where xxxx is the hexadecimal Unicode code point, generates a Unicode-encoded (UTF-16) character.
                                                      Shortly I'll explain explain the first two methods further. The 3rd is more problematic to work with. First, you may have to edit your registry and add a the REG_SZ value  "HKEY_Current_User/Control Panel/Input Method/EnableHexNumpad", then set it to "1". Also, depending on where you are trying to type the character the application may interpret your hexadecimal Fs as attempts to bring down the file menu. Since method three is so problematic I'll focus on the first two methods.
                                                      First, make sure you are using the number pad and not the top roll number keys, only the number pad works for this. Second, make sure NUM LOCK is on. It does not have to be on in all cases for these key combos to work, but it helps by keeping the number pad from being misinterpreted.
                                                      The chart below shows the relevant key codes to get various symbols. The table on the left shows the OEM Extended ASCII character set (AKA: IBM PC Extended Character Set; Extended ASCII; High ASCII; 437 U.S. English). True ASCII is only 7 bit, so the range is 0 to 127. IBM extended it to 8 bits and added more characters. To type these characters you merely have to hold down an ALT key, type the numeric value of the character, then release the ALT key.
                                                      The table on the right shows the ANSI character set (AKA: Window's ANSI/ISO Latin-1/ANSI Extended ASCII, though technically they are not exactly the same thing.). To use the ANSI character set you do the same thing as the OEM set, but you preface the number with an extra zero. Notice that the first 127 should be the same in both sets, though values 0-31 may not be viewable in all cases. I've been in "character encoding hell" just trying to get this article on my site in a readable format.
                                                      I'm only covering the first 256 characters of both sets in my chart, in some cases you can go higher but it depends on the application you are typing in. For example, ALT+257 gives me ā in Wordpad, but in Notepad it loops back around the character set and gives me☺(257-256=1 which is ☺ in the OEM set) . If you want to know what key code will bring up a particular character in a certain Windows font run Windows Character Map (charmap.exe) and look in the bottom right corner to find out.
                                                      I hope this information is useful to some of you, I'll be referring back to it when I start to write my hardware key logger reviews. Check out the links at the bottom of this page for further information on the topic.
                                              IBM (AKA: OEM) / PC Extended ASCII
                                              <td< td="">
                                              ALT+0
                                              ALT+1
                                              ALT+2
                                              ALT+3
                                              ALT+4
                                              ALT+5
                                              ALT+6
                                              ALT+7
                                              ALT+8
                                              ALT+9
                                              ALT+10
                                              ALT+11
                                              ALT+12
                                              T+13
                                              ALT+14
                                              ALT+15
                                              ALT+16
                                              ALT+17
                                              ALT+18
                                              ALT+19
                                              ALT+20
                                              ALT+21§
                                              ALT+22
                                              ALT+23
                                              ALT+24
                                              ALT+25
                                              ALT+26
                                              ALT+27
                                              ALT+28
                                              ALT+29
                                              ALT+30
                                              ALT+31
                                              ALT+32
                                              ALT+33!
                                              ALT+34"
                                              ALT+35#
                                              ALT+36$
                                              ALT+37%
                                              ALT+38&
                                              ALT+39'
                                              ALT+40(
                                              ALT+41)
                                              ALT+42*
                                              ALT+43+
                                              ALT+44,
                                              ALT+45-
                                              ALT+46.
                                              ALT+47/
                                              ALT+480
                                              ALT+491
                                              ALT+502
                                              ALT+513
                                              ALT+524
                                              ALT+535
                                              ALT+546
                                              ALT+557
                                              ALT+568
                                              ALT+579
                                              ALT+58:
                                              ALT+59;
                                              ALT+60<
                                              ALT+61=
                                              ALT+62>
                                              ALT+63?
                                              ALT+64@
                                              ALT+65A
                                              ALT+66B
                                              ALT+67C
                                              ALT+68D
                                              ALT+69E
                                              ALT+70F
                                              ALT+71G
                                              ALT+72H
                                              ALT+73I
                                              ALT+74J
                                              ALT+75K
                                              ALT+76L
                                              ALT+77M
                                              ALT+78N
                                              ALT+79O
                                              ALT+80P
                                              ALT+81Q
                                              ALT+82R
                                              ALT+83S
                                              ALT+84T
                                              ALT+85U
                                              ALT+86V
                                              ALT+87W
                                              ALT+88X
                                              ALT+89Y
                                              ALT+90Z
                                              ALT+91[
                                              ALT+92\
                                              ALT+93]
                                              ALT+94^
                                              ALT+95_
                                              ALT+96`
                                              ALT+97a
                                              ALT+98b
                                              ALT+99c
                                              ALT+100d
                                              ALT+101e
                                              ALT+102f
                                              ALT+103g
                                              ALT+104h
                                              ALT+105i
                                              ALT+106j
                                              ALT+107k
                                              ALT+108l
                                              ALT+109m
                                              ALT+110n
                                              ALT+111o
                                              ALT+112p
                                              ALT+113q
                                              ALT+114r
                                              ALT+115s
                                              ALT+116t
                                              ALT+117u
                                              ALT+118v
                                              ALT+119w
                                              ALT+120x
                                              ALT+121y
                                              ALT+122z
                                              ALT+123{
                                              ALT+124|
                                              ALT+125}
                                              ALT+126~
                                              ALT+127
                                              ALT+128Ç
                                              ALT+129ü
                                              ALT+130é
                                              ALT+131â
                                              ALT+132ä
                                              ALT+133à
                                              ALT+134å
                                              ALT+135ç
                                              ALT+136ê
                                              ALT+137ë
                                              ALT+138è
                                              ALT+139ï
                                              ALT+140î
                                              ALT+141ì
                                              ALT+142Ä
                                              ALT+143Å
                                              ALT+144É
                                              ALT+145æ
                                              ALT+146Æ
                                              ALT+147ô
                                              ALT+148ö
                                              ALT+149ò
                                              ALT+150û
                                              ALT+151ù
                                              ALT+152ÿ
                                              ALT+153Ö
                                              ALT+154Ü
                                              ALT+155¢
                                              ALT+156£
                                              ALT+157¥
                                              ALT+158
                                              ALT+159ƒ
                                              ALT+160á
                                              ALT+161í
                                              ALT+162ó
                                              ALT+163ú
                                              ALT+164ñ
                                              ALT+165Ñ
                                              ALT+166ª
                                              ALT+167º
                                              ALT+168¿
                                              ALT+169
                                              ALT+170¬
                                              ALT+171½
                                              ALT+172¼
                                              ALT+173¡
                                              ALT+174«
                                              ALT+175»
                                              ALT+176
                                              ALT+177
                                              ALT+178
                                              ALT+179
                                              ALT+180
                                              ALT+181
                                              ALT+182
                                              ALT+183
                                              ALT+184
                                              ALT+185
                                              ALT+186
                                              ALT+187
                                              ALT+188
                                              ALT+189
                                              ALT+190
                                              ALT+191
                                              ALT+192
                                              ALT+193
                                              ALT+194
                                              ALT+195
                                              ALT+196
                                              ALT+197
                                              ALT+198
                                              ALT+199
                                              ALT+200
                                              ALT+201
                                              ALT+202
                                              ALT+203
                                              ALT+204
                                              ALT+205
                                              ALT+206
                                              ALT+207
                                              ALT+208
                                              ALT+209
                                              ALT+210
                                              ALT+211
                                              ALT+212
                                              ALT+213
                                              ALT+214
                                              ALT+215
                                              ALT+216
                                              ALT+217
                                              ALT+218
                                              ALT+219
                                              ALT+220
                                              ALT+221
                                              ALT+222
                                              ALT+223
                                              ALT+224α
                                              ALT+225ß
                                              ALT+226Γ
                                              ALT+227π
                                              ALT+228Σ
                                              ALT+229σ
                                              ALT+230µ
                                              ALT+231τ
                                              ALT+232Φ
                                              ALT+233Θ
                                              ALT+234Ω
                                              ALT+235δ
                                              ALT+236
                                              ALT+237φ
                                              ALT+238ε
                                              ALT+239
                                              ALT+240
                                              ALT+241±
                                              ALT+242
                                              ALT+243
                                              ALT+244
                                              ALT+245
                                              ALT+246÷
                                              ALT+247
                                              ALT+248°
                                              ALT+249
                                              ALT+250·
                                              ALT+251
                                              ALT+252
                                              ALT+253²
                                              ALT+254
                                              ALT+255
                                              ALT+00
                                              ALT+01
                                              ALT+02
                                              ALT+03
                                              ALT+04
                                              ALT+05
                                              ALT+06
                                              ALT+07
                                              ALT+08
                                              ALT+09
                                              ALT+010
                                              ALT+011
                                              ALT+012
                                              ALT+013
                                              ALT+014
                                              ALT+015
                                              ALT+016
                                              ALT+017
                                              ALT+018
                                              ALT+019
                                              ALT+020
                                              ALT+021
                                              ALT+022
                                              ALT+023
                                              ALT+024
                                              ALT+025
                                              ALT+026
                                              ALT+027
                                              ALT+028
                                              ALT+029
                                              ALT+030
                                              ALT+031
                                              ALT+032
                                              ALT+033!
                                              ALT+034"
                                              ALT+035#
                                              ALT+036$
                                              ALT+037%
                                              ALT+038&
                                              ALT+039'
                                              ALT+040(
                                              ALT+041)
                                              ALT+042*
                                              ALT+043+
                                              ALT+044,
                                              ALT+045-
                                              ALT+046.
                                              ALT+047/
                                              ALT+0480
                                              ALT+0491
                                              ALT+0502
                                              ALT+0513
                                              ALT+0524
                                              ALT+0535
                                              ALT+0546
                                              ALT+0557
                                              ALT+0568
                                              ALT+0579
                                              ALT+058:
                                              ALT+059;
                                              ALT+060<
                                              ALT+061=
                                              ALT+062>
                                              ALT+063?
                                              ALT+064@
                                              ALT+065A
                                              ALT+066B
                                              ALT+067C
                                              ALT+068D
                                              ALT+069E
                                              ALT+070F
                                              ALT+071G
                                              ALT+072H
                                              ALT+073I
                                              ALT+074J
                                              ALT+075K
                                              ALT+076L
                                              ALT+077M
                                              ALT+078N
                                              ALT+079O
                                              ALT+080P
                                              ALT+081Q
                                              ALT+082R
                                              ALT+083S
                                              ALT+084T
                                              ALT+085U
                                              ALT+086V
                                              ALT+087W
                                              ALT+088X
                                              ALT+089Y
                                              ALT+090Z
                                              ALT+091[
                                              ALT+092\
                                              ALT+093]
                                              ALT+094^
                                              ALT+095_
                                              ALT+096`
                                              ALT+097a
                                              ALT+098b
                                              ALT+099c
                                              ALT+0100d
                                              ALT+0101e
                                              ALT+0102f
                                              ALT+0103g
                                              ALT+0104h
                                              ALT+0105i
                                              ALT+0106j
                                              ALT+0107k
                                              ALT+0108l
                                              ALT+0109m
                                              ALT+0110n
                                              ALT+0111o
                                              ALT+0112p
                                              ALT+0113q
                                              ALT+0114r
                                              ALT+0115s
                                              ALT+0116t
                                              ALT+0117u
                                              ALT+0118v
                                              ALT+0119w
                                              ALT+0120x
                                              ALT+0121y
                                              ALT+0122z
                                              ALT+0123{
                                              ALT+0124|
                                              ALT+0125}
                                              ALT+0126~
                                              ALT+0127
                                              ALT+0128
                                              ALT+0129
                                              ALT+0130
                                              ALT+0131ƒ
                                              ALT+0132
                                              ALT+0133
                                              ALT+0134
                                              ALT+0135
                                              ALT+0136ˆ
                                              ALT+0137
                                              ALT+0138Š
                                              ALT+0139
                                              ALT+0140Œ
                                              ALT+0141
                                              ALT+0142Ž
                                              ALT+0143
                                              ALT+0144
                                              ALT+0145
                                              ALT+0146'
                                              ALT+0147"
                                              ALT+0148"
                                              ALT+0149
                                              ALT+0150
                                              ALT+0151
                                              ALT+0152˜
                                              ALT+0153
                                              ALT+0154š
                                              ALT+0155
                                              ALT+0156œ
                                              ALT+0157
                                              ALT+0158ž
                                              ALT+0159Ÿ
                                              ALT+0160
                                              ALT+0161¡
                                              ALT+0162¢
                                              ALT+0163£
                                              ALT+0164¤
                                              ALT+0165¥
                                              ALT+0166¦
                                              ALT+0167§
                                              ALT+0168¨
                                              ALT+0169©
                                              ALT+0170ª
                                              ALT+0171«
                                              ALT+0172¬
                                              ALT+0173
                                              ALT+0174®
                                              ALT+0175¯
                                              ALT+0176°
                                              ALT+0177±
                                              ALT+0178²
                                              ALT+0179³
                                              ALT+0180´
                                              ALT+0181µ
                                              ALT+0182
                                              ALT+0183·
                                              ALT+0184¸
                                              ALT+0185¹
                                              ALT+0186º
                                              ALT+0187»
                                              ALT+0188¼
                                              ALT+0189½
                                              ALT+0190¾
                                              ALT+0191¿
                                              ALT+0192À
                                              ALT+0193Á
                                              ALT+0194Â
                                              ALT+0195Ã
                                              ALT+0196Ä
                                              ALT+0197Å
                                              ALT+0198Æ
                                              ALT+0199Ç
                                              ALT+0200È
                                              ALT+0201É
                                              ALT+0202Ê
                                              ALT+0203Ë
                                              ALT+0204Ì
                                              ALT+0205Í
                                              ALT+0206Î
                                              ALT+0207Ï
                                              ALT+0208Ð
                                              ALT+0209Ñ
                                              ALT+0210Ò
                                              ALT+0211Ó
                                              ALT+0212Ô
                                              ALT+0213Õ
                                              ALT+0214Ö
                                              ALT+0215×
                                              ALT+0216Ø
                                              ALT+0217Ù
                                              ALT+0218Ú
                                              ALT+0219Û
                                              ALT+0220Ü
                                              ALT+0221Ý
                                              ALT+0222Þ
                                              ALT+0223ß
                                              ALT+0224à
                                              ALT+0225á
                                              ALT+0226â
                                              ALT+0227ã
                                              ALT+0228ä
                                              ALT+0229å
                                              ALT+0230æ
                                              ALT+0231ç
                                              ALT+0232è
                                              ALT+0233é
                                              ALT+0234ê
                                              ALT+0235ë
                                              ALT+0236ì
                                              ALT+0237í
                                              ALT+0238î
                                              ALT+0239ï
                                              ALT+0240ð
                                              ALT+0241ñ
                                              ALT+0242ò
                                              ALT+0243ó
                                              ALT+0244ô
                                              ALT+0245õ
                                              ALT+0246ö
                                              ALT+0247÷
                                              ALT+0248ø
                                              ALT+0249ù
                                              ALT+0250ú
                                              ALT+0251û
                                              ALT+0252ü
                                              ALT+0253ý
                                              ALT+0254þ
                                              ALT+0255ÿ
                                              Links:
                                              How to enter Unicode characters in Microsoft Windows
                                              http://www.fileformat.info/tip/microsoft/enter_unicode.htm
                                              ASCII and Unicode and other character encodings
                                              http://qcpages.qc.cuny.edu/~nixon/links/asciiUnicode.html
                                              Microsoft Character sets
                                              http://www.microsoft.com/typography/unicode/cs.htm
                                              Wikipedia Article on Windows Alt Keycodes
                                              http://en.wikipedia.org/wiki/Windows_Alt_Keycodes
                                                  Jim Steinmeyer
                                                  Dan,
                                                  Yes I know that these symbols are readily available using the Windows Character Map. That is how I placed them in the above message. Yes they are readily available there. However my memory isn't the best for something I don't use frequently. Symbols like the diameter or centerline symbols are readily available there too, however if they are in the SW symbol folder there are fewer clicks or mouse travel than if I have to open the Char Map, select and copy to place them.
                                              John Stoltzfus
                                              If you want to try something different and add your own symbols, take a look at Rob Edwards replies here
                                              What are your most impressive tricks of solidworks, Please spread.
