3 Replies Latest reply on Jun 23, 2017 6:31 AM by Dave Bear
    Dimension Properties
    Yong Ning
      Private Sub ll()
         Dim swApp As SldWorks.SldWorks, swModel As ModelDoc2
             Set swModel = swApp.ActiveDoc
         Dim SwSelMgr As SelectionMgr
             Set SwSelMgr = swModel.SelectionManager
         Dim swDispDim As DisplayDimension, swDim As Dimension
             Set swDispDim = SwSelMgr.GetSelectedObject5(1)
             With swDispDim
                 .ArrowSide = swDimArrowsInside
                 .SetArrowHeadStyle False, swCLOSED_ARROWHEAD  ' swNO_ARROWHEAD
                 Debug.Print .GetArrowHeadStyle
                 '.SetOverride False, 10 '"<DIM>"
                 .SetBrokenLeader2 False, swBrokenLeaderAlignedText  'swBrokenLeaderHorizontalText  ' swSolidLeaderAlignedText
                 Debug.Print .GetBrokenLeader2
             End With
             swModel.ForceRebuild3 True
      swDimensionArrowsSide_e
      swDimArrowsInside - Always positioned on the inside.
      swDimArrowsOutside - Always positioned on the outside.
      swDimArrowsSmart - Positioned on the inside, if there is room; otherwise, positioned on the outside.
      swDimArrowsFollowDoc - As per the document's default setting.
      swSolidLeaderAlignedText - The leader is solid (not broken) and the text is aligned with the leader.
      swBrokenLeaderHorizontalText - The leader is broken and the text is horizontal.
      swBrokenLeaderAlignedText - The leader is broken and the text is aligned with the leader.
      How to Align Dimension with API ? | SOLIDWORKS Forums  https://forum.solidworks.com/message/690260
      How to determine the number of multiple dimensi... | SOLIDWORKS Forums  https://forum.solidworks.com/message/570899#comment-570899
      Have dimension → how to set DisplayDimension | SOLIDWORKS Forums  https://forum.solidworks.com/message/378125#comment-378125
      Rotate the dimension text orientation with API? | SOLIDWORKS Forums  https://forum.solidworks.com/message/473296
      How to set the Radial Dimension Text Position? | SOLIDWORKS Forums  https://forum.solidworks.com/message/429020
      How to display dimension of Horizontal Text wit... | SOLIDWORKS Forums  https://forum.solidworks.com/message/366384
      Vertical Ordinate Dimensions → with API | SOLIDWORKS Forums  https://forum.solidworks.com/message/385093
      How to Get dimension Name in Traverse Assembly | SOLIDWORKS Forums  https://forum.solidworks.com/message/292035#comment-292035
      Get Display Dimension Type - API | SOLIDWORKS Forums  https://forum.solidworks.com/message/317119#comment-317119
        • Re: Dimension Properties
          Yong Ning
          Dim Str
          Sub MoveDimAnn()
             Dim SkPt As SketchPoint, SkSketch As Sketch
             Dim SkPtArr, SwSegMent As SketchSegment
             Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                 Set SwApp = Application.SldWorks
                 Set SwModel = SwApp.ActiveDoc
                 SwModel.ClearSelection2 False
                 'Set SkPt = SwModel.CreatePoint2(0, 0, 0)
             Dim SwDraw As DrawingDoc
                 Set SwDraw = SwModel
             Dim SwSheet As Sheet, SwView As View
                 Set SwSheet = SwDraw.GetCurrentSheet
                 Set SwView = SwDraw.GetFirstView
             Dim SwMathUtil As MathUtility
                 Set SwMathUtil = SwApp.GetMathUtility
                 Set SwSelMgr = SwModel.SelectionManager
             Dim SwDispDim As DisplayDimension, SwDim As Dimension, SwAnn As Annotation
             Dim AnnPos, Ss, SwMathPt(2) As MathPoint
             Dim Xy(2, 1) As Double, Xy1(2, 1), Xy2(2, 1)
             Dim Arr As Variant
                 Do While Not SwView Is Nothing
                     Set SwDispDim = SwView.GetFirstDisplayDimension
                     Do While Not SwDispDim Is Nothing
                          Arr = DimMathPtArr(SwModel, SwMathUtil, SwView, SwDispDim)
                          MathPtMoveDim SwModel, SwMathUtil, SwView, SwDispDim, Arr(0), Arr(1)
                          Set SwDispDim = SwDispDim.GetNext
                     Loop
                     Set SwView = SwView.GetNextView
                 Loop
          Function DimMathPtArr(SwModel As ModelDoc2, SwMathUtil As MathUtility, SwView As View, SwDispDim As DisplayDimension)
               Dim Arr(2) As Variant, AnnPos As Variant
               Dim SwDim As Dimension, SwAnn As Annotation
               Dim SwMathPt(2) As MathPoint
               Dim SwXForm As MathTransform
               Dim RefPt, Dist
                  Set SwXForm = SwView.ModelToViewTransform
                  With SwDispDim
                      Set SwDim = .GetDimension
                      Debug.Print SwDim.FullName, SwDispDim.Type2,
                      DispDimType SwDispDim
                      Str = SwDim.FullName & "@" & SwView.Name
                      ''Debug.Print Str
                      Ss = SwDim.ReferencePoints
                      For ii = 0 To 2
                          Set SwMathPt(ii) = Ss(ii)
                          Set SwMathPt(ii) = SwMathPt(ii).MultiplyTransform(SwXForm)
                      Next ii
                      Set SwAnn = .GetAnnotation
                      'SwAnn.SetPosition 0#, -0.09, 0
                      'SwAnn.SetPosition 0#, 0.05, 0
                      AnnPos = SwAnn.GetPosition
                   End With
                   For ii = 0 To 2
                       For jj = 0 To 1
                           Xy1(ii, jj) = SwMathPt(ii).ArrayData(jj)
                           Xy(ii, jj) = Round(AnnPos(jj) - Xy1(ii, jj), 6) / SwView.ScaleDecimal
                       Next jj
                   Next ii
                      'If SwDim.FullName = "H@Web1@¸¹°å.Part" Then
                      If SwDim.FullName = "W@Web1@¸¹°å.Part" Then
                          'SwAnn.Select False
                          Stop
                   If Xy1(0, 1) = Xy1(1, 1) Then
                        Arr(0) = "0,1"
                           If Xy(0, 1) > 0 Then
                               Arr(1) = 10
                           ElseIf Xy(0, 1) < 0 Then
                               Arr(1) = -10
                   ElseIf Xy1(0, 0) = Xy1(1, 0) Then
                        Arr(0) = "0,0"
                           If Xy(0, 0) > 0 Then
                               Arr(1) = 10
                           ElseIf Xy(0, 0) < 0 Then
                               Arr(1) = -10
                   Else
                        Arr(0) = Empty
                        Arr(1) = Empty
                   If SwDispDim.Type2 = 2 Then
                       If Xy1(1, 1) = Xy1(2, 1) Then
                          Arr(0) = "0,0"
                          If Xy(1, 0) > 0 Then
                              Arr(1) = 10
                          ElseIf Xy(1, 0) < 0 Then
                              Arr(1) = -10
               DimMathPtArr = Arr
          End Function
          Function MathPtMoveDim(SwModel As ModelDoc2, SwMathUtil As MathUtility, _
                   SwView As View, SwDispDim As DisplayDimension, _
                   RefPt, Dist)
               Dim Xx, Yy
                  With SwDispDim
                      For ii = 0 To 2
                      Next ii
                   End With
                   For ii = 0 To 2
                       For jj = 0 To 1
                           Xy(ii, jj) = SwMathPt(ii).ArrayData(jj) '/ SwView.ScaleDecimal
                       Next jj
                   Next ii
                   Xx = AnnPos(0)
                   Yy = AnnPos(1)
               Dim Rr, Cc
                   If Not IsEmpty(RefPt) Then
                       Ss = Split(RefPt, ",")
                       Rr = Ss(0)
                       Cc = Ss(1)
                       Select Case RefPt
                            Case "0,0", "1,1"
                                 Xx = Xy(Rr, Cc) + Dist / 1000
                            Case "0,1"
                                 Yy = Xy(Rr, Cc) + Dist / 1000
                       End Select
                       Select Case SwDispDim.Type2
                            Case 2, 12
                                 SwAnn.SetPosition Xx, Yy, 0
                       End Select
          End Function
            Peter Brinkhuis
            Do you have a question for us?
