I am currently creating something with surfaces. However when I want to create a 2-line boundary surface I will get an Error clicking the second line.
After doing a lot of research and testing I am still not able to create a boundary surface, I am probably doing something wrong.
- To test if it was just the file or sketch I tried to create a simplistic boundary surface, however I was still getting the error.
- Trying different sketch lines also didn't help (Line, 3point arc, Spline, Style spline)
- I asked my friend to send me a Surface using the 2-line technique, for him it was working fine (SW2014). On opening the file I also got the surface working perfectly. However when I edit the feature and then deselect and reselect one of the lines it will give me the same error. (Adjusting the splines will let me adjust the surface
- I removed Solidworks 2015 and updated to 2016, this didn't help
- I swept my registry to clean and reset all my settings, this didn't help either.
The “error” can be seen in the image attached
What am I doing wrong? I spent so much time trying to find the solution and it’s driving me crazy ;). If you have any idea please tell me.
Tanks!
Thomas
UPDATE: I tried to use a different method creating with the boundary surface feature, this also gave me the error up on selecting the line
Thomas, please make sure that the two arcs intersect each other. If You could upload the file, we would be able to help you better.
