Hello All,
Any reason why the corner relief feature would be inactive in this environment? Please advise. SW 2015 SP 3
Nick
Hello All,
Nick
Nicholas, was this file created in 2012 or older version? If yes then corner relief won't be available per Solution Id:S-065742.
The only option/workaround is to recreate the file using 2013 or higher version.
Deepak,
It is a new part file, created in SW 2015 SP 3. I can add a corner relief to a simple rectangular sheet-metal part with edge flanges on all sides. I created a copy of my desired part and deleted all features except for the edge flanges. It still shows that the corner relief is inactive. I would not think that it is an issue with the method that the edge flange was created because SW recognizes the corner in the flat state using the corner-trim feature.
Thank you,
Nick
Attached is a simplified model (removed gussets, weldnuts, etc.) which still doesn't have the ability to use the "Corner Relief" command (adding relief in bent state). I can however add the relief in the flattened state using the "Corner-Trim" command.
Thank you,
Nick
I started from scratch and it seems to work for me. I am guessing this was an added feature in a newer version and your part started from an older part. See if this works for you.
Edited: Sorry, this is in 2016 so it won't do you much good.
See the attached video. Something went wrong creating your sheet metal component. Start from scratch and see if it happens again. I am a bit suspicious about your gauge table (watch the end of the video), but as you can see I still have access to the corner relief option.
Nicholas, this could be issues with the file or some regression. Please submit the file to your VAR for further investigation.
