Hello everybody. Who have the behavior about use move face after trim in weldment ? When I selected bodies to make the drawing the drawing are wrong dimension.
I think this problem is from move face command.
you can try my attached model to check this problem.
Hi Anuwat,
Don't use move faces in weldment's if cutlist information is critical. It can cause cutlist length errors in some applications. Stick with extrude instead. It's more stable.
