I'm having trouble manipulating drawing tolerances via rule. I have captured the dimensions I want to manipulate (w/ the symmetric tolerance enabled), and created a variable for the tolerances based on the length of the part. Problem is I can't figure out the right code to get the drawing to display the tolerance defined by the rule. It continues to output [Dimension]+/-.000.
Does anyone know the code to get this to work correctly? I have tried the Driveworks standard help that is something along the lines of
[Dimension]&"|"&[Lower Tol]&"|"&[Upper Tol]&"|"&[Tol Type] but could not get it to work. Any help is greatly appreciated! Thank you!
