We have an in house application that uses the PDM Works API
to get a file from the database and then we use eDrawings2008 to
print the drawing. The problem we are noticing is that we will run
the application once, and the drawing will print out with just
arrows and lines, but no dimensions or title bar, etc. We can try
it again and the same thing will happen. Then, if we continue with
the same drawing, it will eventually print out as a complete
drawing without any problems.
I am at a loss as to why it is doing that. It started a couple weeks ago after we moved from SmarTeam to PDMWorks and from eDrawings 2006 to 2008.
I am not convinced it is an eDrawings issue, but I think it could be a good place to start. Thanks,
Jon
Jon
