Re: How do I see inside a box in an assembly (I want to manipulate internal features)?
Tony Cantrell Feb 23, 2017 10:30 AM (in response to P. K.)Make the box transparent, select it in the tree or assy and choose the transparent icon.
Siavash Khajehhasani Feb 23, 2017 10:33 AM (in response to P. K.)select other and keep right clicking
test 3.mp4 1.1 MB
John Pesaturo Feb 23, 2017 11:37 AM (in response to Siavash Khajehhasani)I find the "Select Other" option to be very straight forward and use it all the time in some reasonably complex assemblies. It's never let me down. The box that pops up also highlights your selection.
Typically when doing this I have the assembly toggled into "Hidden Lines Visible" mode.
Peter De Vlieger Feb 23, 2017 11:18 AM (in response to P. K.)Or use the tab key while hovering over the offending item to hide the part. Using shift+tab to bring the part back.
Tom dunn Feb 23, 2017 11:22 AM (in response to P. K.)But he needs the box to still be visible so he can mate to the walls, If he hides the box then its gone.
Deepak Gupta Feb 23, 2017 11:43 AM (in response to P. K.)You can use Shift (keep it pressed while selection) to select the transparent face.
And if you're using SW2016, then you can take advantage of the component preview window and transparent component during mating.
Alin Vargatu Feb 23, 2017 8:34 PM (in response to P. K.)With the Magnifying Glass on (G), Hold Alt and rotate the mouse wheel to X-Ray into the assembly. Then select the inner entities at will.
Swapnil Dhake Feb 23, 2017 9:53 PM (in response to Alin Vargatu)Hey this feature is great, it's today I came to know such a feature exists. Thank you Alin !
