Set configuration when inserting BOM into drawing
Question asked by Chris Manger on Feb 22, 2017
Latest reply on Jun 27, 2018 by Chris Manger
I am using the VBA example in the help file (LINK).   The API help states when using TopLevelOnly, that the BomFeature property must be used.   I added some some to get the configuration used in the selected view.   How do I set to BOM to this configuration?    If I use the code from the help file, the configuration using in the view does not get set in the BOM table properties.  For example, if the selected view is referencing a configuration called "XYZ", how do I set the BOM to configuration XYZ?
' Because BOM type is swBomType_TopLevelOnly,
  ' then work with BomFeature to get and set configurations
  Set swBomFeat = swBomAnn.BomFeature
  Names = swBomFeat.GetConfigurations(False, Visible)
  Visible(0) = True
  boolstatus = swBomFeat.SetConfigurations(True, Visible, Names)
Message was edited by: Chris M.
