Hi All.
My first post here, firstly let me thank you.
I would like a macro that does the following, open each part of an assembly and saves the part as a step and the drawing as PDF.
The STEP and PDF should then be saved in an already existing folder that has the same name as the part.
Can someone help me? I'm not that experienced with macro programming.
Thank you
You can use these codes as changes as needed.
