I need to break the corners of many parts
The default valve is 0.1" in my computer
However, my boss wants 1/8.
Is there any way that I can set the default valve from 0.1" to 1/8?
You could try:
In your sldprt template create a basic extrusion. Then chamfer a face with .125
Delete the features and save your template.
The value might stick. I'm only guessing because if you put in a chamfer value, that value pops up the next time you add another chamfer.
I am not a doctor, I don't even play one on tv
Not sure if this can be done as 10 mm is a default for metric unit unless you want to break in to the registry (not recommend if you're not familiar with editing registry)
