SFSteve Fye21/02/2017
This macro is designed to work from Excel.  I've been struggling with this for 3 days now and can't figure out how to get it to give me consistent results.  Here's what's going on:
The goal is to do this:
1.  Have the assembly active (Assem1.SLDASM)
2.  Press the "Grab Dimension" button from Excel
3.  Select the component (SSM-Straight-Section NO DESIGN TABLE.SLDPRT) in the assembly.
4.  Grab the ModelDoc from the selected part and read the value of 2 named dimensions in the part.  One dimension is named "length@frame@SSM-Straight-Section TEST.SLDPRT", the other is "chain-width@Sketch3@SSM-Straight-Section TEST.SLDPRT"
5.  Enter those values into the spreadsheet.
Now, for the most part, this Excel/VBA program WORKS...  It allows selection, grabs the component, even gets dimensions, but here's the problem... if I change the configuration of the part from within the assembly and run the macro again, it does not grab the most current dimensions after the rebuild (See the results posted below).  What's really weird is that if I open the component, then go back to the assembly, then run the macro again, it works fine (with correct dimension values).
You'll notice that the macro uses 5 different methods for grabbing the dimension value, and there's not one single method that gives me the right "combination" of values that I can use.
I'd really really appreciate any help I can get with this.
Here is what the output looks like
Here is what the output SHOULD look like
Download files here
Here's the code:
Public swApp               As Object
Public swModel             As Object
Public swReferenceModel    As Object
Public swSelComp           As Object
Public swSelMgr            As Object
Public swDisplayDimension  As Object
Public swDimension  As Object
Public DimensionName, SelectedComponentParam_ConfigurationName As String
Public vConfigNameArray As Variant
Public vConfigName As Variant
Public sSpecConfigNameArr(0) As String
Public vSpecConfigNameArr As Variant
Sub GrabbingDimensionIssue()
    'Attach to SolidWorks from Excel,
    'call routine to grab a component
    'and get the dimensions from it
    Set swApp = GetObject(, "Sldworks.Application")
    Set swModel = swApp.ActiveDoc
    SelectComponentInAssembly
    If Not swSelComp Is Nothing Then
        ExtractDataFromSelectedComponent
Sub SelectComponentInAssembly()
    'Allows user to select a component from the assembly.
    'Sets up the selection manager and the ModelDoc for
    'the selected component
    Dim All As Boolean
    swModel.ClearSelection2 (All)
    Set swReferenceModel = Nothing
    Set swSelComp = Nothing
    Set swSelMgr = Nothing
    Do While swSelComp Is Nothing
        Set swSelComp = swSelMgr.GetSelectedObjectsComponent2(1)
        DoEvents
    Loop
Sub ExtractDataFromSelectedComponent()
    'Name of component in the model tree
    SelectedComponentParam_SSMComponentName = swSelComp.Name
    'Get active configuration name of referenced component
    'Also set up array for configuraitons of selected component
    Set swReferenceModel = swSelComp.GetModelDoc
    SelectedComponentParam_ConfigurationName = swSelComp.ReferencedConfiguration
    vConfigNameArray = swReferenceModel.GetConfigurationNames
    'Title info for selected component
    Range("B1") = Now()
    Range("B2") = SelectedComponentParam_ConfigurationName
    'Grab values for LENGTH dimension using different methods
    DimensionName = "length@frame@SSM-Straight-Section NO DESIGN TABLE.SLDPRT"
    boolstatus = swReferenceModel.Extension.SelectByID2(DimensionName, "DIMENSION", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
    Set swSelMgr = swReferenceModel.SelectionManager
    Set swDisplayDimension = swSelMgr.GetSelectedObject6(1, 0)
    Set swDimension = swDisplayDimension.GetDimension
    DimensionValue = 0
    Set swDisplayDimension = swReferenceModel.Parameter(DimensionName)
    DimensionValue1 = swReferenceModel.Parameter(DimensionName).Value
    DimensionValue2 = swDisplayDimension.GetValue2(SelectedComponentParam_ConfigurationName)
    DimensionValue3 = swDisplayDimension.GetSystemValue2(SelectedComponentParam_ConfigurationName)
    DimensionValue4 = swDisplayDimension.SystemValue
    DimensionValue5Array = swDimension.GetSystemValue3(1, vConfigNameArray)
    DimensionValue5 = DimensionValue5Array(0)
    Range("B7") = DimensionValue1
    Range("B8") = DimensionValue2
    Range("B9") = DimensionValue3
    Range("B10") = DimensionValue4
    Range("B11") = DimensionValue5
    'Grab values for CHAIN WIDTH dimension using different methods
    DimensionName = "chain-width@Sketch3@SSM-Straight-Section NO DESIGN TABLE.SLDPRT"
    DimensionValue = 0
    Range("C7") = DimensionValue1
    Range("C8") = DimensionValue2
    Range("C9") = DimensionValue3
    Range("C10") = DimensionValue4
    Range("C11") = DimensionValue5
