I have been working on a part and all of a sudden some features(i.e. a sketch or a fillet, so anything really) cant be unsuppressed or suppressed. There is no option for it. Does anybody know why this is?
Can you share the part? And maybe exactly where you were and what process you tried to use to suppress/unsuppress?
The reason that I ask, is, as an example, that if you are in an assembly and are modifying a part in context, then the suppress/unsuppress buttons don't show up for the components until you exit the in context modification of the part.
Is it something like that?
Well, it all depends on the specific scenario. It sounds like the example that I gave is NOT the issue here, if I understand correctly.
The reason that I am asking for more details is that I am not sure how much of a user you are. Giving more information will clue us in to what things to try.
How about a screen shot of the issue?
I understand your concern. I'm really sure hot to explain my level of being a user besides that ive had 3 semesters of solidworks classes at college 1 and a half years in industry and 2 training courses. One specific to assemblies.
Here is the screen shot you asked for.
Its a sketched I used so that later down the tree I had a consistent location for a specific feature which only has one child(which is in a different configuration that is not being used in the assembly).
My first intuition matched Dan's, that of assembly in-context editing focusing only on that context.
Do any other users have access to the PC you're using? More specifically, could someone have customized the Solidworks UI that you are using? Do you have an OCD intern? It appears to me that your missing commands from the RMB pane could simply have been removed by someone's customization. This is very odd to me, as I usually consider customization for adding icons, not removing them.
Try adding it back in with UI Customization. If my UI was really messed up, I would revert it to a saved Settings Wizard file, or reset the UI, depending on how many other options need restored.
No one else has access or are able to accesses my computers files. And it will work on the other features as shown. This is not the only one in the tree that does not show the suppress option though. There are a couple others but all of their parents are unsuppressed.
And no. Flat Tree is not enabled. Hope this is easier to see as well.
Can you upload a simple file which is showing this behavior? Does you part has configuration, multi bodies or exploded view?
Check #18 of Forum Posting on how to attach files while replying to a post.
When I open the part and immediately perform a CTRL-Q, there is a warning:
If I select 'Continue', several features fail, others have warnings. At this point, it's time to start deconstructing the model, removing features until the bad behavior goes away. Step one is to eliminate all the folders. They just get in the way at this point. Next, starting from the bottom of the tree and working your way up, delete features until the bad behavior goes away. Also, delete any features that have no children, regardless of where they are in the tree. This takes the model from 233 features, down to 28, but still exhibits the bad behavior. Delete all the other configurations, just to make things even simpler. Your feature tree now looks like this:
All six items at the bottom exhibit the bad behavior (can't unsuppress). If you delete the last feature, the bad behavior goes away. You can't unsupress the last feature because its suppression state is controlled by an equation.
If you delete the equation, the problem goes away and everything can be unsupressed. So, I made a simple test part with three extrude features stacked up. I made an equation that set the suppressed state of the last feature to always be suppressed. I see the same behavior. Any features that are parents of the feature controlled by an equation cannot be suppressed/unsuppressed. This is most definitely a bug in 2017, since 2016 doesn't exhibit the behavior. The complexity and errors in your model made it difficult to find the problem, but that's why saving a copy and deconstructing it is worth doing.
