One gusset is created in one corner. Is it possible to have 3 images of this gusset in other 3 corners using Circular Pattern tool? Because all body is a square like structure.
Yes - If you have the frame built/assembled with your front or right plane in the center of the frame, then add a vertical Construction line in one of those planes and then use that line to revolve your pattern..
As John said above, you can do this. I would personally add an axis in the center of your frame and pattern about the axis. You will need to pattern the body of the gusset.
Yes, it's very possible. I created an axis at the intersection of the Front and Right planes, and used that for "Direction 1". Be sure you de-select "Features and Faces" and select "Bodies".
