In Drawing ,Annotation.GetPosition result is Error
Question asked by Yong Ning on Feb 19, 2017
Latest reply on Feb 19, 2017 by Yong Ning
In Drawing,  follow code is error.
       Set SwAnn = SwNote.GetAnnotation
       Ss = SwAnn.GetPosition
follow code result is error.
Private Sub ll3()
   Dim swApp As SldWorks.SldWorks, SwModel As ModelDoc2
       Set SwModel = swApp.ActiveDoc
   Dim SwDraw As DrawingDoc
       Set SwDraw = SwModel
   Dim SwSelMgr As SelectionMgr
       Set SwSelMgr = SwModel.SelectionManager
   Dim SwNote As Note, SwAnn As Annotation
   Dim SwPt As SketchPoint, SwPt1 As SketchPoint
       Set SwNote = SwSelMgr.GetSelectedObject5(1)
       Set SwPt = SwModel.CreatePoint2(Ss(0), Ss(1), 0)
       Debug.Print "Ss Coordinate is ", Ss(0), Ss(1)
       With SwPt
           Debug.Print "Pt Coordinate is ", .x, .y, .Z
       End With
       Stop
Sub Del()
    Dim SwMathUtil As MathUtility
    Dim SwSketch                As SldWorks.Sketch
    Dim swSketchLine            As SldWorks.SketchLine
    Dim swSkStartPt             As SldWorks.SketchPoint
    Dim swSkEndPt               As SldWorks.SketchPoint
    Dim nPt(2)                  As Double
    Dim vPt                     As Variant
    Dim swStartPt               As SldWorks.MathPoint
    Dim swEndPt                 As SldWorks.MathPoint
    Dim swEnt                   As SldWorks.Entity
    Dim swSkXform               As SldWorks.MathTransform
        Set SwMathUtil = swApp.GetMathUtility
        Set swSketchLine = SwSelMgr.GetSelectedObject5(1)
        Set swSkStartPt = swSketchLine.GetStartPoint2
        Set swSkEndPt = swSketchLine.GetEndPoint2
        Set SwSketch = SwModel.GetActiveSketch
        Set swSkXform = SwSketch.ModelToSketchTransform
        Set swSkXform = swSkXform.Inverse
        nPt(0) = swSkStartPt.x
        nPt(1) = swSkStartPt.y
        nPt(2) = swSkStartPt.Z
        vPt = nPt
        Set swStartPt = SwMathUtil.CreatePoint(vPt)
        Set swStartPt = swStartPt.MultiplyTransform(swSkXform)
        nPt(0) = swSkEndPt.x
        nPt(1) = swSkEndPt.y
        nPt(2) = swSkEndPt.Z
        vPt = nPt
        Set swEndPt = SwMathUtil.CreatePoint(vPt)
        Set swEndPt = swEndPt.MultiplyTransform(swSkXform)
        Debug.Print "File = " & SwModel.GetPathName
        Debug.Print "    Start wrt sketch   = (" & swSkStartPt.x * 1000# & ", " & swSkStartPt.y * 1000# & ", " & swSkStartPt.Z * 1000# & ") mm"
        Debug.Print "    End   wrt sketch   = (" & swSkEndPt.x * 1000# & ", " & swSkEndPt.y * 1000# & ", " & swSkEndPt.Z * 1000# & ") mm"
        Debug.Print "    Start wrt model    = (" & swStartPt.ArrayData(0) * 1000# & ", " & swStartPt.ArrayData(1) * 1000# & ", " & swStartPt.ArrayData(2) * 1000# & ") mm"
        Debug.Print "    End   wrt model    = (" & swEndPt.ArrayData(0) * 1000# & ", " & swEndPt.ArrayData(1) * 1000# & ", " & swEndPt.ArrayData(2) * 1000# & ") mm"
Private Sub del20170221()
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
        Set SwMathUtil = SwApp.GetMathUtility
    Dim SwDispDim As DisplayDimension, SwAnn As Annotation
        Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
        Set SwAnn = SwDispDim.GetAnnotation
    Dim vPos, vPt(2) As Double
        vPos = SwAnn.GetPosition
    Dim AttEnt, AttEntTypes
        AttEnt = SwAnn.GetAttachedEntities2
        AttEntTypes = SwAnn.GetAttachedEntityTypes
    Dim SwSketch As Sketch, SwSkXForm As MathTransform
        Set SwSkXForm = SwSketch.ModelToSketchTransform
        Set SwSkXForm = SwSkXForm.Inverse
    Dim SkPt As SketchPoint, SkLine As SketchLine, SkSeg As SketchSegment
        Set SkPt = AttEnt(0)
    Dim SwPt As MathPoint, Pp(2)
        'Set SkPt = AttEnt(0)
        With SkPt
            Debug.Print .x, .y, .Z
            Debug.Print vPos(0), vPos(1), vPos(2)
            vPt(0) = .x
            vPt(1) = .y
        End With
        Set SwPt = SwMathUtil.CreatePoint(vPt)
        Set SwPt = SwPt.MultiplyTransform(SwSkXForm)
        With SwPt
            Debug.Print .ArrayData(0), .ArrayData(1), .ArrayData(2)
            'SwAnn.SetPosition .ArrayData(0), .ArrayData(1) + 0.008, .ArrayData(2)
            SwAnn.SetPosition .ArrayData(0), .ArrayData(1) - 0.025, .ArrayData(2)
        End With
        SwModel.ForceRebuild3 True
