I have a scene in my project which I like and I would like to use this scene in different projects. My question is when I save the scene will it save all lighting, background color and everything else in the environment so I can get the same effect in the other project?
Hi Mukesh,
The best way to achieve your end result is to set up your entire scene in Visualize...geometry, materials, textures, lighting (HDR) and cameras. Then as soon as you are all set, delete your model and save this as a new Visualize project. Then you can open this Visualize project, pop in your new model and start rendering immediately. All materials, lighting and cameras will be saved in that single Visualize project file.
Here is a good example, from a watch designer. They only design watches and small objects like that, so they set up a complete project in Visualize, and then deleted the watch model from it. Now they use this as their default Visualize project for every other watch. And all they have to do is import the new watch model, drag over there preset materials and then simply kick off the renders.
They built the sweep background in SOLIDWORKS and imported that over to Visualize as well. The white planes you see have an Emissive appearance on them, so they are actually like additional lights you would set up in a photo studio. It's a really fast workflow.
