8 Replies Latest reply on Feb 21, 2017 3:41 AM by Deepak Gupta
    Problem with #task and .sts
    Eimantas Palevicius
      I am trying to use #Task to export all parts in the folder to *.sat format. When I add my .swp macro to #Task it works perfectly. But I need to set an argument saving location. I am trying to do this by this tutorial. After setting arguments and saving script to .sts  file type (see attachement) the #Task does not work. It gives me: Generic error. This indicates that task failed to run a macro. Please make sure that you can run macros in solidworks. Anyone knows what I am doing wrong?
      This is .swp code that works:
      Dim MyPath As String
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim strFilePath As String
      Dim lngPathSize As Long
      Dim strNewFilePath As String
      Dim ret As Boolean
      Dim lngPathPos1 As Long
      Dim lngPathPos2 As Long
      Dim strFileName As String
      Dim lngError As Long
      Dim lngWarning As Long
      Set swModel = swApp.ActiveDoc
      Set swModelDocExt = swModel.Extension
      strFilePath = swModel.GetPathName
      lngPathSize = Strings.Len(strFilePath)
      lngPathPos2 = Strings.InStrRev(strFilePath, ".", -1, vbTextCompare)
      lngPathPos1 = Strings.InStrRev(strFilePath, "\", -1, vbTextCompare)
      strFileName = Strings.Mid(strFilePath, lngPathPos1 + 1, (lngPathPos2 - lngPathPos1) - 1)
      MyPath = "D:\Darbinis katalogas\Macro\Bandymam\SAT"
      strNewFilePath = MyPath & "\" & strFileName & ".sat"
      swModelDocExt.SaveAs strNewFilePath, 0, 1, Nothing, lngError, lngWarning
      Regards
      E.P.
