Hello every body,
I have a problem with de date of sw documents put in the doc properties.
If I put a date in the doc custom properties with date as type of value in july, when summer time ends the date changes to the day before.
If you want to try this, you should change your system to summer time, july for exemple, create a file with a property of date type and save it with any value in. Then turn your system to winter time and the date will change to the day before
Anybody has the same problem?
Thank you
Thank you
