I have a curved sail that I created in sheet metal. My questions is can I change the bending point to the middle. The way I have it now it bends from a corner.
Another question I have is when I created this sail I drew to curves one on top and the other on bottom and then used the sheet metal lofted-bend to make it a one solid part. Does any one know if this sail can be done using just one curve? Thank you.
I don't think you need sheet metal for this. just do a surface sweep with guide curves to get the shape you want
