3 Replies Latest reply on Feb 24, 2017 7:14 PM by Raghvendra Bhargava
    Assembly macro multiple folders
    Nick Makkinga
      I have a macro to make DXF and PDF files from my opened assembly, works perfectly. But I have one problem.
      My assembly constist of components from different folders, so it makes multiple PDF and DXF folders in the same location of the parts.
      Is it possible to make just one DXF/PDF folder in the same folder as the location of the openend assembly where all my files will be exported to?
      Props to Simon for this macro!!
      '* OK, this isn't the tidiest bit of code I've ever written            *
      '* & it's mostly cobbled together from examples in the Solidworks API  *
      '* Documentation - but it works OK!                                    *
      '* To use, you need to have an assembly open.  It will find all the    *
      '* linked drawings (must have same name as model) and export to PDF    *
      '* It then finds all the SheetMetal parts, exports them to DXF and     *
      '* builds a BOM for them - to be sent to your favorite Laser Cutter    *
      '* Mail me at simon1@psi-design.co.uk if you want to tell be how cool  *
      '* you think it is! (or tell me if you've found a problem!)            *
      Option Explicit
      Dim swExportPDFData As SldWorks.ExportPdfData
      Sub ShowAllOpenFiles()
      Dim swDoc As SldWorks.ModelDoc2
      Dim swAllDocs As EnumDocuments2
      Dim FirstDoc As SldWorks.ModelDoc2
      Dim NumDocsReturned As Long
      Dim DocCount As Long
      Dim bDocWasVisible As Boolean
      Dim OpenWarnings As Long
      Dim OpenErrors As Long
      Dim DwgPath As String
      Dim myDwgDoc As SldWorks.ModelDoc2
      Dim drwPathName As String
      Dim pdfPathName As String
      Dim pdfFolderName As String
      Dim lErrors As Long
      Dim lWarnings As Long
      Dim sMessage As String
      Dim nExported As Integer
      Dim fso As Scripting.FileSystemObject
      Dim FeatureDefinition As SheetMetalFeatureData
      Dim prtPath As String
      Dim featureMgr As Feature
      Dim SheetMetalFolder As Folder
      Set swAllDocs = swApp.EnumDocuments2
      Set FirstDoc = swApp.ActiveDoc
      On Error Resume Next
          If FirstDoc.GetType <> swDocASSEMBLY Then
              MsgBox "I'm afraid this macro only works when run" & vbCr & "from within a top level assembly!"
              Exit Sub
          nExported = 0
          DocCount = 0
          swAllDocs.Reset
          swAllDocs.Next 1, swDoc, NumDocsReturned
          While NumDocsReturned <> 0
              bDocWasVisible = swDoc.Visible
              'swApp.ActivateDoc swDoc.GetPathName'
              DwgPath = swDoc.GetPathName
              If (LCase(Right(DwgPath, 3)) = "prt") Then
                  'Open model
                  'Export any sheet metal parts as DXF Flat patterns
                  prtPath = Left(DwgPath, Len(DwgPath) - 3) & "prt"
                  Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocPART, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
                  Set featureMgr = myDwgDoc.FeatureManager
                  Set SheetMetalFolder = featureMgr.GetSheetMetalFolder
              If (LCase(Right(DwgPath, 3)) <> "drw") And (DwgPath <> "") Then
                  DwgPath = Left(DwgPath, Len(DwgPath) - 3) & "drw"
                  Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocDRAWING, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
                  If Not myDwgDoc Is Nothing Then
                      swApp.ActivateDoc myDwgDoc.GetPathName
                      'Extract the root folder for assembly and create a PDF folder inside
                      pdfFolderName = Left(DwgPath, InStrRev(DwgPath, "\")) & "PDF Drawings\"
                      Set fso = CreateObject("Scripting.FileSystemObject")
                      If (Not fso.FolderExists(pdfFolderName)) Then
                          MkDir pdfFolderName
                      Dim Part As ModelDoc2
                      Set Part = swApp.ActiveDoc()
                      'You have a drawing active
                      drwPathName = Part.GetPathName()
                      If ("" = drwPathName) Then
                      ' GetPathName() was empty
                          MsgBox ("This drawing has not been saved yet")
                          Exit Sub
                      pdfPathName = fso.BuildPath(pdfFolderName, fso.GetBaseName(drwPathName) & ".pdf")
                      Set swExportPDFData = swApp.GetExportFileData(1)
                      swExportPDFData.ViewPdfAfterSaving = False
                      Part.Extension.SaveAs pdfPathName, 0, 0, swExportPDFData, lErrors, lWarnings
                      swApp.QuitDoc (Part.GetTitle)
                      Set myDwgDoc = Nothing
                      nExported = nExported + 1
              DocCount = DocCount + 1
          Wend
          sMessage = "PDF/DXF/BOM Export       " & vbCr & vbCr
          If nExported = 0 Then
              sMessage = sMessage & "No Drawings found to export to PDF" & vbCr & vbCr
          Else
              sMessage = sMessage & CStr(nExported) & " PDF's saved to: " & vbCr & pdfFolderName & vbCr & vbCr
          swApp.ActivateDoc FirstDoc.GetPathName
          'Generate & save the BOM for sheet metal parts
          sMessage = sMessage & ExportSheetBOM() 'Returns info on DXF's exported if any
          MsgBox sMessage
      Function ExportSheetBOM() As String
      'Counts the instances of sheet metal parts in Assembly (and su=assemblies)
      Dim swMyDoc As SldWorks.ModelDoc2
      Dim swSelComp As SldWorks.Component2
      Dim CurSelCount As Long
      Dim GeneralSelObj As Object
      Dim AllComponents As Variant
      Dim i As Long
      Dim TopLevOnly As Boolean
      Dim SupCount As Long
      Dim LwtCount As Long
      Dim ResCount As Long
      Dim sMsg As String
      Dim CompPath As String
      Dim EachComp As SldWorks.Component2
      'Bill of Materials
      Dim sPartNames() As String
      Dim nPartQty() As Integer
      Dim sPartMaterial() As String
      Dim sPartThickness() As String
      Dim nCnt As Integer
      Dim nThickness As Double
      Dim sMatDB As String
      Dim mFSO As Scripting.FileSystemObject
      Dim firstfeature As Feature
      Dim nextfeature As Feature
      Dim Thickness As Double
      Dim bRebuild As Boolean
      Dim bRet As Boolean
      Dim sBOM As String
      Dim ComponentRoot As String
      Dim ComponentName As String
      Dim Material As String
      Dim EachName As String
      Dim dxfFolderName As String
      Dim dxfFileName As String
      Dim NewFilePath As String
      Dim nDXFExported As Integer
      Dim bFound As Boolean
      Dim objTextStream As Object
      'Dim swSelMgr As SldWorks.SelectionMgr
      Dim swView As SldWorks.View
      Dim swDrawModel As SldWorks.ModelDoc2
      Dim lErrors As Long
      Dim fsoForWriting As Variant
      Dim sDXFPath As String
          ReDim Preserve sPartNames(0)
          ReDim Preserve nPartQty(0)
          ReDim Preserve sPartMaterial(0)
          ReDim Preserve sPartThickness(0)
          Set swDoc = swApp.ActiveDoc
          Set swAssy = swDoc
          Set swSelMgr = swDoc.SelectionManager
          CompPath = swDoc.GetPathName
          CompPath = swSelMgr.GetPathName
          'Find component name.
          ComponentRoot = Left(CompPath, InStrRev(CompPath, "\"))
          ComponentName = Mid(CompPath, InStrRev(CompPath, "\") + 1)
          ComponentName = Left(ComponentName, InStrRev(ComponentName, ".") - 1)
          TopLevOnly = False
          AllComponents = swAssy.GetComponents(TopLevOnly)
          SupCount = 0
          ResCount = 0
          LwtCount = 0
          For i = 0 To UBound(AllComponents)
              Set EachComp = AllComponents(i)
              Set firstfeature = EachComp.firstfeature
              Set nextfeature = firstfeature.GetNextFeature
              Material = "Not Set"
              Do While (Not (firstfeature Is Nothing))
                  If nextfeature.GetTypeName = "SheetMetal" Then
                      'This part has sheet metal
                      Set FeatureDefinition = nextfeature.GetDefinition
                      Set swMyDoc = swApp.OpenDoc6(EachComp.GetPathName, swDocPART, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
                      DwgPath = swMyDoc.GetPathName
                      EachName = Mid(EachComp.GetPathName, InStrRev(EachComp.GetPathName, "\") + 1)
                      EachName = Left(EachName, InStrRev(EachName, ".") - 1)
                      bRebuild = swMyDoc.ForceRebuild3(False)
                      dxfFolderName = Left(DwgPath, InStrRev(DwgPath, "\")) & "DXF Flat Patterns\"
                      dxfFileName = Mid(DwgPath, InStrRev(DwgPath, "\") + 1)
                      'Loose Extension
                      dxfFileName = Left(dxfFileName, InStrRev(dxfFileName, ".") - 1)
                      NewFilePath = dxfFolderName & dxfFileName & ".DXF"
                      'Now create path
                      If (Not fso.FolderExists(dxfFolderName)) Then
                          MkDir dxfFolderName
                      Set fso = Nothing 'destroy object
                      'Export Flat Pattern
                      bRet = swMyDoc.ExportFlatPatternView(NewFilePath, 1)
                      nDXFExported = nDXFExported + 1
                      Material = swMyDoc.MaterialIdName
                      If InStr(Material, "SOLIDWORKS Materials|") > 0 Then
                          Material = Mid(Material, InStr(Material, "SOLIDWORKS Materials|") + 21)
                      If InStr(Material, "|") > 0 Then
                          Material = Left(Material, InStr(Material, "|") - 1)
                      Thickness = FeatureDefinition.Thickness * 1000 'put in to mm
                      'Look through array for component name
                      bFound = False
                      For nCnt = 1 To UBound(sPartNames)
                          If UCase(sPartNames(nCnt)) = UCase(EachName) Then
                              'Inc qty
                              nPartQty(nCnt) = nPartQty(nCnt) + 1
                              bFound = True
                      Next
                      If Not bFound Then
                          ReDim Preserve sPartNames(UBound(sPartNames) + 1)
                          ReDim Preserve nPartQty(UBound(sPartNames) + 1)
                          ReDim Preserve sPartMaterial(UBound(sPartNames) + 1)
                          ReDim Preserve sPartThickness(UBound(sPartNames) + 1)
                          sPartNames(UBound(sPartNames)) = EachName
                          nPartQty(UBound(sPartNames)) = 1
                          sPartThickness(UBound(sPartNames)) = Thickness
                          sPartMaterial(UBound(sPartNames)) = Material
                      swApp.QuitDoc (swMyDoc.GetTitle)
                  Set firstfeature = nextfeature.GetNextFeature
                  If (Not (firstfeature Is Nothing)) Then
                      'Debug.Print nextfeature.GetTypeName
              Loop
          Next i
          ExportSheetBOM = ""
          If UBound(sPartNames) > 0 Then
              'We should now have an array we can save as a CSV
              'Finally Export a CSV of the BOM
              'Extract the root folder for assembly and create a DXF folder inside
              sDXFPath = Left(swDoc.GetPathName, InStrRev(swDoc.GetPathName, "\")) & "DXF Flat Patterns\"
              Dim objFSO
              Set objFSO = CreateObject("Scripting.FileSystemObject")
              If (objFSO.FileExists(sDXFPath & "BOM Sheet Metal.csv")) Then
                  objFSO.DeleteFile sDXFPath & "BOM Sheet Metal.csv", True
              'Open the text file
              Set objTextStream = objFSO.CreateTextFile(sDXFPath & ComponentName & "-Sheet BOM.csv", fsoForWriting, True)
              'Write a header line to the file
              objTextStream.WriteLine "PART NAME, MATERIAL, THICKNESS(mm), QUANTITY"
              'Field headings for Laser Lee
              'objTextStream.WriteLine "PART NAME,MATERIAL,GRADE,THICKNESS(mm),GRAIN,OVERWRITE,QUANTITY,NOTES,NOT FOR MANUFACTURE"
              For nCnt = 1 To UBound(sPartNames())
                  'objTextStream.WriteLine sPartNames(nCnt) & "," & sPartMaterial(nCnt) & "," & sPartThickness(nCnt) & "," & nPartQty(nCnt)
                  'Special including Gonfiguration
                  'Fields for Laser Lee
                  'objTextStream.WriteLine sPartNames(nCnt) & "," & sPartMaterial(nCnt) & "," & sPartMaterial(nCnt) & "," & sPartThickness(nCnt) & "," & "N," & "1," & nPartQty(nCnt) & ",- ,0 "
              Next
              'Close the file and clean up
              objTextStream.Close
              Set objTextStream = Nothing
              Set objFSO = Nothing
              If nDXFExported > 0 Then
                  ExportSheetBOM = CStr(nDXFExported) & " DXF's + BOM saved to: " & vbCr & sDXFPath & "BOM Sheet Metal.csv" & vbCr & vbCr
              Else
                  ExportSheetBOM = "No DXF's Exported" & vbCr & vbCr
      End Function
        • Re: Assembly macro multiple folders
          Raghvendra Bhargava
          Replace:
                  Exit Sub
          With:
                  Exit Sub
          Dim PDFPath As String
          PDFPath = Left(FirstDoc.GetPathName, InStrRev(FirstDoc.GetPathName, "\"))
          Replace:
          With:
              pdfFolderName = PDFPath & "PDF Drawings\"
          I guess it should work!!
              Nick Makkinga
              Thanks Raghvendra,
              Works like a charm! Is it possible to do the same for the DXF folders that are created?
                  Raghvendra Bhargava
                  To Export BOM:
                  Replace:
                          Exit Sub
                  With:
                          Exit Sub
                  Dim swFeat As Feature
                  Set swFeat = FirstDoc.FirstFeature
                  Do While Not swFeat Is Nothing
                      Dim SubFeat As Feature
                      Set SubFeat = swFeat.GetFirstSubFeature
                      Do While Not SubFeat Is Nothing
                          If "BomFeat" = SubFeat.GetTypeName Then
                              Dim AssmPath As String
                              AssmPath = Left(FirstDoc.GetPathName, InStrRev(FirstDoc.GetPathName, "\"))
                              'Path to Export BOM as '.xls'
                              Dim BOMFolderName As String
                              BOMFolderName = Left(AssmPath, InStrRev(AssmPath, "\")) & "BOM\"
                              Dim fso As Object
                              If (Not fso.FolderExists(BOMFolderName)) Then
                                  MkDir BOMFolderName
                              Dim BomFeat As BomFeature
                              Set BomFeat = SubFeat.GetSpecificFeature2
                              Dim vTblBOM As Variant
                              vTblBOM = BomFeat.GetTableAnnotations
                              If IsEmpty(vTblBOM) = False Then
                                  Dim BomTblAnn As BomTableAnnotation
                                  Set BomTblAnn = vTblBOM(0)
                                  Dim TblAnn As TableAnnotation
                                  Set TblAnn = BomTblAnn
                                  boolstatus = TblAnn.SaveAsText(BOMFolderName & FirstDoc.GetTitle & "_BOM.xls", "")
                                  If boolstatus = False Then swApp.SendMsgToUser "BOM for " & Part.GetTitle & " is not generated."
                                  Exit Do
                           Set SubFeat = SubFeat.GetNextFeature
                      Loop
                      Set swFeat = swFeat.GetNextFeature
                  Loop
