9 Replies Latest reply on Jun 15, 2017 5:07 AM by Alexey Kovalov
    SW macro generate excel with drawing referenced models
    Alexey Kovalov
      Hello everyone!
      Is it possible to make macro wich generate MS Excel file with names of SW drawings (A) and referenced models (B) from directory (and subdirectories)? SW2010
      Thanks for advance/
      Alexey
        • Re: SW macro generate excel with drawing referenced models
          Viktor Bovzdarenko
          Hi Alexey,
          there are a few ways to make such macro.
          One of the ways is to use:
          IModelDoc2 : GetDependencies2 or swApp:GetDocumentDependencies2
          It will allow to get referenced to drawing models without opening them. Hence only in a second or so you will be able recursively collect all data and output it to Excel.
          Regards
          Viktor
            Keith Rice
            This would probably be better handled with Document Manager API, if you want it to run as fast as possible.
            Keith
            SolidWorks API Training and Services
              Alexey Kovalov
              Hello!
              Viktor, Matt thanks for your answers.
              Now I can get  dependences for open or not open drawing.
              Option Explicit
                  ' Name of unopened document
                  Const sDefaultName      As String = "C:\Dwg 1.SLDDRW"
                  Dim swApp               As SldWorks.SldWorks
                  Dim swModel             As SldWorks.ModelDoc2
                  Dim sDocName            As String
                  Dim vDepend             As Variant
                  Dim bRet                As Boolean
                  Dim i                   As Long
                  Set swModel = swApp.ActiveDoc
                  If Not swModel Is Nothing Then
                      sDocName = swModel.GetPathName
                  Else
                      sDocName = sDefaultName
                  vDepend = swApp.GetDocumentDependencies2(sDocName, True, True, False)
                  Debug.Print sDocName
                  If IsEmpty(vDepend) Then
                      Debug.Print "    No dependencies."
                      Exit Sub
                  For i = 0 To (UBound(vDepend) - 1) / 2
                      Debug.Print "    " + vDepend(2 * i) + " --> " + vDepend(2 * i + 1)
                  MsgBox "Ìîäåëü" + ": " + vDepend(2 * i) + " --> " + vDepend(2 * i + 1)
                  Next i
              Now I need to get this data for all drawings from one directory and subdirectories and output it to excel file.
              How can I do this?
              Maybe anyone have an example for similar task?
              I have an excel vba macro to make open directory dialog (choose directory) but this code doesnt work in SW
              With Application.FileDialog(msoFileDialogFolderPicker)
                      .Title = "Âûáåðèòå ïàïêó èëè äèñê"
                      .Show
                      On Error Resume Next
                      Err.Clear
                      V = .SelectedItems(1)
                      If Err.Number <> 0 Then
                          MsgBox "Âû íè÷åãî íå âûáðàëè!"
                          Exit Sub
                  End With
                  BrowseFolder = CStr(V)
                Alexey Kovalov
                Hello!
                I modify macro and now it get drawing dependencies and output it to excel file.
                Option Explicit
                    Const sDefaultName      As String = "C:\dwg1.SLDDRW"
                    Dim bRet                As Boolean
                    Dim i                   As Long
                    Dim sTitle              As String
                    Dim xlApp               As Excel.Application
                    Dim xlBk                As Excel.Workbook
                    Dim xlSht               As Excel.Worksheet
                    Dim curCol              As Long
                    Dim curRow              As Long
                    Else
                    vDepend = swApp.GetDocumentDependencies2(sDocName, False, True, False)
                        Exit Sub
                    'Run Excel
                    Set xlApp = New Excel.Application
                    xlApp.Visible = True
                    Set xlBk = xlApp.Workbooks.Add
                    Set xlSht = xlBk.Worksheets(1)
                    xlSht.Cells(1, 1).Value = "Drawing"
                    xlSht.Cells(1, 2).Value = "Referenced part/assembly"
                    curCol = 2
                    curRow = 2
                        'xlSht.Cells(curRow, curCol).Value = vDepend(2 * i)
                        'curCol = curCol + 1
                        xlSht.Cells(curRow, curCol).Value = vDepend(2 * i + 1)
                        'curCol = 2
                        curRow = curRow + 1
                    Next i
                    Columns("A:E").AutoFit
                Now I need to make possibility to select folder and get dependencies for all drawings in folder and subfolders and output it to excel.
                Tell me please, how can I do this?
                Regards.
                Alexey
