Hoping someone can offer me some assistance.
I'm currently using the following snippet to delete files from a directory. Right now, I'm looking for an explicit filename. However, I would like something closer to KillFilePDF = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & ***<----ANY TEXT AFTER THIS*** ".PDF"
The filename for after the IMPN variable always contains a space before it if it has a revision. I'm currently looking through Revision F, but I would like to change this to delete ANY revision level file that lives out there.
'DELETE EXISTING PDF AND DWG FILES FROM SALES FOLDER, REGARDLESS OF REVISION AND CERT SUFFIXES
Dim KillFilePDF As String
KillFilePDF = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & ".PDF"
Debug.Print KillFilePDF
'Check that file exists
If Len(Dir$(KillFilePDF)) > 0 Then
'First remove readonly attribute, if set
SetAttr KillFilePDF, vbNormal
'Then delete the file
Kill KillFilePDF
Dim KillFilePDFREVA As String
KillFilePDFREVA = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV A.PDF"
Debug.Print KillFilePDFREVA
If Len(Dir$(KillFilePDFREVA)) > 0 Then
SetAttr KillFilePDFREVA, vbNormal
Kill KillFilePDFREVA
Dim KillFilePDFREVB As String
KillFilePDFREVB = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV B.PDF"
Debug.Print KillFilePDFREVB
If Len(Dir$(KillFilePDFREVB)) > 0 Then
SetAttr KillFilePDFREVB, vbNormal
Kill KillFilePDFREVB
Dim KillFilePDFREVC As String
KillFilePDFREVC = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV C.PDF"
Debug.Print KillFilePDFREVC
If Len(Dir$(KillFilePDFREVC)) > 0 Then
SetAttr KillFilePDFREVC, vbNormal
Kill KillFilePDFREVC
Dim KillFilePDFREVD As String
KillFilePDFREVD = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV D.PDF"
Debug.Print KillFilePDFREVD
If Len(Dir$(KillFilePDFREVD)) > 0 Then
SetAttr KillFilePDFREVD, vbNormal
Kill KillFilePDFREVD
Dim KillFilePDFREVE As String
KillFilePDFREVE = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV E.PDF"
Debug.Print KillFilePDFREVE
If Len(Dir$(KillFilePDFREVE)) > 0 Then
SetAttr KillFilePDFREVE, vbNormal
Kill KillFilePDFREVE
Dim KillFilePDFREVF As String
KillFilePDFREVF = "M:\Public - Sales\Email Drawings" & "\" & IMIPN & " REV F.PDF"
Debug.Print KillFilePDFREVF
If Len(Dir$(KillFilePDFREVF)) > 0 Then
SetAttr KillFilePDFREVF, vbNormal
Kill KillFilePDFREVF
Two tips for this. 1) Dir allows wildcards. 2) Dir without an argument repeats the prior search and gets the next match. So, this should work:
strFileSpec = "M:\Public - Sales\Email Drawings\" & IMIPN & "*.PDF"
KillFilePDF = Dir(strFileSpec)
Do While KillFilePDF <> ""
Kill KillFilePDF
KillFilePDF = Dir
Loop
