2016 clear memory cache so files can be moved
Question asked by Aaron Conner on Feb 15, 2017
Latest reply on Feb 15, 2017 by Keith Rice
When I close the file in Solidworks I need to be able to move it in windows.  I created a macro in 2015 that closed the current file and opened up a random file (simple square block) thus clearing the memory.  Anyways, now we are in 2016 and that no longer works.  Any ideas on how to fix this would be great.  Thanks,
p.s.  Here's what the macro was.
' C:\Users\aconner\AppData\Local\Temp\swx3920\Macro1.swb - macro recorded on 02/26/15 by aconner
'  Pre-condition:  Files need to be opened
'  Post-condition:  All files excluding unsaved files with be closed and memory of already saved files erased.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
' If IncludeUnsaved is False, then all documents, excluding any unsaved documents, are closed
    boolstatus = swApp.CloseAllDocuments(False)
    Debug.Print boolstatus
Set Part = swApp.OpenDoc6("S:\Checkable\62C-ORG\Part4.SLDPRT", 1, 0, "", longstatus, longwarnings)
swApp.ActivateDoc2 "Part4.SLDPRT", False, longstatus
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameLeft = 0
myModelView.FrameTop = 0
myModelView.FrameState = swWindowState_e.swWindowMaximized
Set Part = Nothing
swApp.CloseDoc "Part4.SLDPRT"
