I'm modeling a plate that will be bent 360° and seam welded. I can't seem to the bend to revolve without interference. Any thoughts?
I suspect what you did is calculate your flat by doing some math. You knew what o.d. or i.d. you wanted and figured out what you thought the blank length should be (circumference). Then did a sketch bend. Whatever,,, your material is is going to stretch thus the overlap (depending on your k-factor).. I would suggest you do as Deepak suggests. Start with a cylinder of the correct size (leave a small gap in an arc of 359.9° or so then flatten it to get your flat pattern size. Use a k-factor of .5 or so should get you real close.
Try 359.5
