Does anyone know how to change the arrow style in autodimension? The Leader display is disable.
Hi Chika ,
this should be able to be accomplished in our document properties under the dimensions area.
make sure to save as a part template if you want to make it a standard
And save your drafting standard so you can use it later if your in a part that was created before you created your new template.
Hello Chika,
If you're referring to these options being disabled, it's because they aren't available in Ordinate Dimensions.
Hi Chika ,
