2 Replies Latest reply on Feb 14, 2017 6:50 PM by Artem Taturevych
    EPDM disappears from Task pane
    Sanya Shmidt
      Hello!
      Not sure why this is happening. When I`m running my app that utilizes SW api, it opens the SW window but I don`t see the EPDM icon...
      This is how task pane should look.
      The code looks normal...
      If swApp Is Nothing Then
                 swApp = CreateObject("SldWorks.Application")
             Else
                 swApp = GetObject("SldWorks.Application.23")
             ' Allow SolidWorks to run in the background and be invisible/invisible
             swApp.UserControl = True : swApp.Visible = True ' True - visible
             ' Opening assembly
             swModel = swApp.OpenDoc6(SWMasterModelSLDASM, swDocumentTypes_e.swDocASSEMBLY, swOpenDocOptions_e.swOpenDocOptions_ReadOnly, "", longstatus, longwarnings)
             swModel = swApp.ActiveDoc
             IsoZoom(swModel)
      Any idea why? I cant even see the available plug in.
      When I start SW manually everything works just fine.
