I was thinking that when making a weldment that Solidworks automatically had an "As Welded" configuration? Then after creating cuts, an "As machined" config showed up. Right now I am only seeing the "As Machined". Other than manually typing the "as welded" how can I get that configuration to show up? Thank you
Expand this arrow and check. The as welded is a derived config under as machined config.
