We are started using solid works toolbox. We have made our own toolbox but the problem is when we use Smart Fastener command then it will allots hardware to the hole wizards. But it allots wrong hardware e.g. in counter bore it allots hex bolt etc.
If any one have solutions for it please do needful.
Also I want some solutions regarding Hole wizard, can we change the type can we change the hole wizard standard from IS to ISO or from one standard form to other?
I would read this thread:
Using Toolbox: Do or Don't?
Personally, we used the toolbox for a while here, but since we use such a large variety of bolts, our bolts became massive (file size) with the amount of information that was in them. Which bogged down even the smallest of assemblies.
Then we switched the setting to "create separate part" rather than configuration, but it still didn't work very well.
There are people here at my facility that use the toolbox, but I personally don't. I just created models for the ones we use the most, labeled them with the part numbers we needed and done.
