Hi!
We're doing a start up and got our entrepreneur licenses and everything in order. Being familiar with EPDM from my day job, I know that it will be a big plus (actually a necessity) for us as the models and product documentation is now starting to pile up. Also we need a proper workflow, revisioning etc. However, the solutions I have heard of are either expensive or too time consuming (VAR or own server solution). A colleague of mine said that we should check out a cloud service provider and see if they could help out, and although I know how to work with EPDM, setups and all, I do not know much about cloud storage of this type.
Has anyone got any experience and/or knowledge on the matter?
Thanks in advance!
My business has setup an Azure cloud server using PDM on the cloud. Now I connect via VPN from anywhere in the world. Latency is an issue on large assemblies only because it has to pull down the file from the file archive to the local cache. Checkout/in is a tad slower but in general it meets all my needs.
EPIGRID is a SOLIDWORKS Solution Partner who has a solution that fits this requirement.
Hope this helps,
Tim CEPAhttps://equivaq.com/
Believe in the Q!
