GetOutline→results different with  rotation or extension method
Question asked by Yong Ning on Feb 7, 2017
Latest reply on Feb 8, 2017 by Yong Ning
Follow code GetOutline ,
The results are different from the rotation method or the extension method
With extendsion method , Correct result
With rotation method , Incorrect result
Function DimBreakOut1(SwDraw As DrawingDoc, SwView As View, DimDepth)
    Dim Var, vPos, tmp, oScale
    Dim SwDim As Dimension, Depth
    Dim DnDim As Dimension, ThkDim As Dimension
    Dim lDim As Dimension
    Dim SwModel As ModelDoc2
        Set SwModel = SwView.ReferencedDocument
        Debug.Print SwModel.GetPathName
    Dim Ww, Hh
        SwDraw.ActivateView SwView.Name
        SwDraw.ForceRebuild3 True
        Var = SwView.GetOutline
        vPos = SwView.Position
        Var(2) = vPos(0) - Var(2)
        Var(3) = vPos(1) - Var(3)
        Var(0) = vPos(0) - Var(0)
        Var(1) = vPos(1) - Var(1)
        For ii = 0 To UBound(Var)
            Var(ii) = Var(ii) / SwView.ScaleDecimal
        Next ii
        With SwDraw
            tmp = .SketchRectangle(Var(0), Var(1), 0, Var(2), Var(3), 0, True)
        End With
End Function
Private Sub ll2()
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
         Set SwApp = Application.SldWorks
         Set SwModel = SwApp.ActiveDoc
    Dim SwSelMgr As SelectionMgr
         Set SwSelMgr = SwModel.SelectionManager
    Dim SwView As View
         Set SwView = SwSelMgr.GetSelectedObject5(1)
         Debug.Print SwView.Name
         DimBreakOut1 SwModel, SwView, ""
