We have a dedicated node for running simulations. Only 1 eng uses the Flow sim license, connects to the sim node and runs sim's. Having completed a sim and logged off the node, he cannot not pick up the license on his own workstation until rebooting.
The License Manager showed the license not in use / available.
Anybody seen similar?
Thank you.
I usually find that closing Solidworks on both machines and then opening again does the trick.
Nevertheless, there is a better way of doing that, you can use the remote solver. This way, the licence will stay with the Engineer's workstation rather than being used up by the node. This will mean they can set up other simulations whilst one is running or even run simulations on multiple computers.
The only requirement is that Solidworks (along with Flow Simulation) is installed on the node computer.
You can do the same thing with Batch Run too.
Hope that helps
Alex
