Hi everyone,
I was wondering if anyone has seen a macro to export all the
bodies of a weldment part to step files. I'm looking at naming the
step files as per the weldment cut list item number but haven't found
anything.
Exemple of what needed:
1- Part number is T-001122 with 3 bodies.
2- Step of body 1 export to T-001122-Item1.STEP
3- Step of body 2 export to T-001122-Item2.STEP
4- Step of body 3 export to T-001122-Item3.STEP.
Not sure if this is possible but you can get the BOM item number with this:
Sub ProcessTableAnn(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swTableAnn As SldWorks.TableAnnotation, ConfigName As String)
Dim nNumRow As Long
Dim J As Long
Dim I As Long
Dim ItemNumber As String
Dim PartNumber As String
Debug.Print " Table Title " & swTableAnn.Title
nNumRow = swTableAnn.RowCount
Dim swBOMTableAnn As BomTableAnnotation
Set swBOMTableAnn = swTableAnn
For J = 0 To nNumRow - 1
Debug.Print " Row Number " & J & " Component Count : " & swBOMTableAnn.GetComponentsCount2(J, ConfigName, ItemNumber, PartNumber)
Debug.Print " Item Number : " & ItemNumber
Debug.Print " Part Number : " & PartNumber
Dim vPtArr As Variant
Dim swComp As Object
Dim pt As Object
Dim compPath As String
vPtArr = swBOMTableAnn.GetComponents2(J, ConfigName)
If (Not IsEmpty(vPtArr)) Then
For I = 0 To UBound(vPtArr)
Set pt = vPtArr(I)
Set swComp = pt
If Not swComp Is Nothing Then
Debug.Print " Component Name :" & swComp.Name2 & " Configuration Name : " & swComp.ReferencedConfiguration
Debug.Print " Component Path :" & swComp.GetPathName
Else
Debug.Print " Could not get component."
Next
Next J
Well hope someone can help me out!
Thanks for any help!
Kevin Chisholm
