Hi everybody,
I'm recieving many Parasolid files coming from Unigraphics and I have to use them as assemblies to modify.
The issue is that the Parasolid is coming with lots of duplicated bodies that I have to delete (maybe a consequence of different layer states into the original file) and when I open it in SW I'm getting a Feature Manager full of duplicated bodies (hundreds) with neutral names as part 1, part 2, part 3, etc.
I'm looking for the fastest way to identify and select any duplicated body in the scene. Is there a feature or something like that?
Thanks!!
You can convert the imported part into weldment. This way all same bodies will be clubbed under one folder and easy to find/delete.
If the file is an assembly file, then convert that assembly into part using Save As option. Set the Save as type as Part and All components option for "Geometry to save"
Now open that converted part, change into weldment and process further.
