SSSafet Seta05/02/2017
I'm a mechanical engineering student and currently I'm working on my final project.
For it I need to simulate the impact of different fluids on the pump, needed power
for a given flow rate and RPM. I'm all new to this simulation thing, all the experiance
I have is from the YouTube tutorials. So far I know how to set the boundary conditions,
rotating regions. The problem starts here: When I put the BC's as enviromental pressure
at inlet and outlet followed by a rotating region at 3000RPM I get a ''vortex crosses the..''
warning message that I can't get rid of. I tried to extend the inlet and outlet pipe but to
no avail and even refined the mesh. When inspecting the surface parameters of inlet and outlet
lid for mass flow rate I get a different reading but in the report mass flow rate is listed as their subtraction
(i.e. m.flow and inlet lid: 3.9205kg/s, outlet lid: -4.2329 kg/s(is the ''-'' a sight it's going out of the system?)
and mass flow rate in report: 0.3123 kg/s) I'd wish to know how to avoid that message
and how to correctly set up my boundary conditions.
For my project the more important thing...
When I set up an inlet mass/volume flow rate followed by an atmospheric pressure at the outlet
I again get a different reading of the inlet/outlet surface mass flow rate reading, but this
time without the warning during the calculation. I would like to know the best way to set the
parameters for my pump, I want to know how to set the volume flow rate that the pump provides
and not the flow rate of the fluid at the inlet pipe(or it's the same thing) and how does the
option relative to rotating frame and absolute impact the results.
The parameters I want to use for my analysis are:
Pump flow rate: 100 m^3/h
Angular velocity: 2500RPM
Goals:
1.Inspect the distribution of velocities/pressure/torque
2. Calculate the needed pump power using the torque from each fluid simulated and angular velocity
The main  question: How to set up the pump to surely get the correct results? (constant mass flow rate, suction pressure...)
I'd be very thankful if any of you could provide me with the help needed to solve these problems so I can finish my project.
The characteristic dimensions of the pump will be provided in the pdf below:
http://i.imgur.com/X5qpHNh.png
Thanks to everyone who finds time to read this and even more thanks to those willing to help out.
Best regards
