Hello, I made a sketch, Surface-Revolved it. Now trying to Extruded-Cut a hole through the object, but the Extruded-Cut option is unavailable, it is greyed out. Not sure, but it seems SolidWorks does not see the Surface-Revolve as a solid body and therefore will not cut it. Thoughts?
Ron,
You appear to have an open contour profile for your revolve. I can't be sure but did you make a revolve surface instead of a revolve Boss/Base?
EDIT: Just double checked what forum I am in. Instead of using an Extrude Cut use the Surface Trim command and you will be able to cut the hole out of the surface.
Also, you could incorporate the hole you are attempting to make into the original sketch's profile and make it in a single feature. You might do that as well.
