Trying to set path to library features for weldment profiles but the Tools, Options menu won't open.....doesn't do anything.
Made sure it wasn't opening in background (Alt-Tab)
Tried it in a new part file with same result. (2016 SP1)
Mark,
Does the program respond to your commands after you try to go into 'Options' or does it continue to respond to your input. The 'Options' dialog may be positioned off-screen. If the program stops responding to your input when you go to 'Options' it would indicate that to be the case.
