Hello. I'm trying to show 3 DOF at one joint (consider ball and socket joint) in one animation.
I had trouble dragging the parts to show exact movement I wanted due to many degrees of freedom.
Mate controller was recommended, but I have SW2015, and buying 2017 is not an option for me as of now...
So! I thought about fixing the parts as much as I need when I need them to produce 1 DOF movement, and then make them to float again so the next DOF can work. First part worked good, but when I made those fixed parts float, and fixed other parts, I saw errors because this new fix/float was applied from the beginning, 0 to n sec...
Is there a way to make certain parts fixed for 0 to 10 sec, and then make other parts fixed for 10 to 20 sec?
Thanks!
Yes. Have the component placed in position using mates (if not done already). And then you can suppress those mates at required time in the motion study. Place the key for the mate you want to suppress at desired time, right click on that key and select Suppress.
