I am trying to write a macro that does two things.
1.) A Control-Q rebuild
2.) Traverse assemblies and all sub-assemblies for nonread-only parts and rebuild any macro feature in them
I am doing this because calling a "full-full" rebuild ( swModel.ForceRebuild3(false) ) takes a very long time for our assemblies because it is literally rebuilding every feature in every part and assembly. This "full-full" rebuild comes from: 2016 SOLIDWORKS API Help - Force Rebuild Example (VBA) and was the start of my macro.
This is currently the only way I know how to force a rebuild on lower level macro features. The macro I am trying to write now is meant to replace the control-Q rebuild and search out my macro features and will hopefully be faster than the "full-full" rebuild
I believe I am close and I think I am stuck on the last step, which is is running the SwComFeature regenerate method. 2015 SOLIDWORKS API Help - Regenerate Method (ISwComFeature)
I've already added the swPublished interface library, but when I try to call the regenerate rebuild I getting "Run-time error '91' : Object variable or with block variable not set"
I believe the problem is that I am not setting my ISWcomFeature object properly. I am still pretty green at writing macros so any help is appreciated. The line that is erroring out is bolded below.
Option Explicit
Public Enum swUserPreferenceIntegerValue_e
swAutoSaveInterval = 3
End Enum
Sub RegenerateMacroFeature(Doc As SldWorks.ModelDoc2)
Dim swFeat As SldWorks.Feature
Dim instance As ISwComFeature
Dim temp As Object
Set swFeat = Doc.FirstFeature
While Not swFeat Is Nothing
If (swFeat.GetTypeName2 = "MacroFeature") Then
Set temp = instance.Regenerate(swApp, Doc, swFeat)
Set swFeat = swFeat.GetNextFeature
Wend
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As SldWorks.Configuration
Dim sPadStr As String
Dim Doc As ModelDoc2
Dim i As Long
For i = 0 To nLevel - 1
sPadStr = sPadStr + " "
Next i
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
Set Doc = swChildComp.GetModelDoc2
If Doc.GetType() = 1 Then
If Doc.IsOpenedReadOnly() = False Then
RegenerateMacroFeature Doc
TraverseComponent swChildComp, nLevel + 1
Debug.Print sPadStr & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & ">"
Next i
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim nStart As Single
Dim i As Long
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
'Turn off automatic save
bRet = swApp.SetUserPreferenceIntegerValue(swAutoSaveInterval, 0)
nStart = Timer
bRet = swModel.ForceRebuild3(True)
TraverseComponent swRootComp, 1
