inserting assembly with smart feature
Question asked by David Boswell on Feb 4, 2017
I have a door assembly which contains a smart feature to cut the hole in the cabinet when the door is located. The door has different configurations allowing the height and width to change. What do I need to do to be able to use this assembly in multiple assemblies without the changes made to the configuration affecting the other assemblies using the same door with a different configuration?
When I insert this assembly now and modify the configuration in one assembly and then open another assembly with the same door, it's updated to the last configuration I used.
