I can't update a Solidworks composer file. The update button is greyed out? I have change the Solidworks model and saved it, but can't bring the new data into the composer file.
Is this an assembly or just one part? Which update button is greyed out? The update under file is to update the whole file while the update button under geometry is used to update selected geometry. I have never seen the update under file greyed out but the update under geometry will be greyed out if no geometry is selected. For what it's worth if this is an assembly and only one part is revised I recommend selecting that part and updating under geometry. This will only update this part and less risk for complications.
If non of this info helps you please attach screenshots of what you are seeing so we can better advise.
Kurt,
Cheers,
Derek
