How to calculate friction force?
i have one part which roll upon a plate?
if i have to calculate the friction force what to select for define the result?
please help...................
Can you please provide a litte more information on how you are setting up the problem and what you want to measure. For example are you using 3-D contact with friction enabled? Is the part being driven or is it free to rotate and you are interested in if it will slip or rotate?
You can extract forces for friction. I forget if you're using 2008 or 2007.
Ian
