2 Replies Latest reply on Feb 2, 2017 5:23 PM by Matt Camacho-Cook
    How to identify missing mate references
    Matt Camacho-Cook
      I have large assemblies with several mates that have been broken due to part geometry/faces changing.  Unfortunately, these mates do not show up as errors in the feature tree and only show up as greyed out (but not suppressed) in the feature tree.  I'm struggling to find a way to identify these via the API.  I've tried the following example from the help, but it does not provide any useful info to show these problematic mates: 2013 SOLIDWORKS API Help - Get Mates and Mate Entities Example (VBA) .
      I have also tried IFeature.GetErrorCode2(), but this returns 0 for no errors and False for the IsWarning (since they aren't showing up in the feature tree as errors).
      Example mate that has lost its references:
      Editing the "Tangent23" mate:
      Is there a way to retrieve the mate selection names above so I could search "**External**Face" and see that I have an error?  I'm on SolidWorks 2013.
      Paul Ryan seemed to have a somewhat similar question with API and Missing Mates .
      Thanks in advance,
      Matt
        • Re: How to identify missing mate references
          Raghvendra Bhargava
          Hi Matt,
          There is no direct API to get the Mate Selection names. As far as i understand You want to get the Mate name which is having Missing Selection reference.
          Below code will give you Mate name which is using Two selection (Like Face and face), and one of the Selection is missing.
          Try this:
          Option Explicit
          Dim swFeat As SldWorks.Feature
          Dim swMateFeat As SldWorks.Feature
          Dim swSubFeat As SldWorks.Feature
          Dim swMate As SldWorks.Mate2
          Dim swMateEnt(2) As SldWorks.MateEntity2
          Dim fileName As String
          Dim errors As Long
          Dim warnings As Long
          Dim i As Long
              Set swModel = swApp.ActiveDoc
              'Get the first feature in the assembly
              Set swFeat = swModel.FirstFeature
              'Iterate over features in FeatureManager design tree
              Do While Not swFeat Is Nothing
                  If "MateGroup" = swFeat.GetTypeName Then
                      Set swMateFeat = swFeat
                      Exit Do
                  Set swFeat = swFeat.GetNextFeature
              Loop
              'Get first mate, which is a subfeature
              Set swSubFeat = swMateFeat.GetFirstSubFeature
              Do While Not swSubFeat Is Nothing
                 Set swMate = swSubFeat.GetSpecificFeature2
                  Dim MateEntCnt As Integer
                  MateEntCnt = swMate.GetMateEntityCount 'Getting Mate Selection Count
                  Dim MateRefCnt As Integer
                  MateRefCnt = 0
                  If Not swMate Is Nothing Then
                      For i = 0 To 1
                          Set swMateEnt(i) = swMate.MateEntity(i)
                          Dim ref As Entity
                          Set ref = swMateEnt(i).Reference 'It will return the Entity object like face, Edge etc.
                          If Not ref Is Nothing Then
                              MateRefCnt = MateRefCnt + 1
                      Next i
                      If MateEntCnt <> MateRefCnt Then Debug.Print swSubFeat.Name & " < is having Missing Mate Selection>" ' Mate name which is having Missing Selection Reference
                  ' Get the next mate in MateGroup
                  Set swSubFeat = swSubFeat.GetNextSubFeature
              Loop
              Matt Camacho-Cook
              Hi Raghvendra,
              Your solution above worked great!  I made a couple of minor changes to make sure the Set swMate = swSubFeat.GetSpecificFeature2 was only acting on mates, as the GetNextSubFeature seemed to be grabbing the derived hole patterns that show up below my mates in my feature tree.
              Here's my final code:
              Option Explicit
              Dim swMateEnt() As SldWorks.MateEntity2
              Dim sFeatType As String
              Dim i As Long
                          Exit Do
                  Loop
                      sFeatType = swSubFeat.GetTypeName2
                      ' GetNextSubFeature starts grabbing derived hole patterns and we only want mates.
                      Select Case sFeatType
                          Case "MateCoincident", "MateParallel", "MatePlanarAngleDim", "MateWidth", "MateConcentric", "MateTangent", "MateCoordinate", "MateSymmetric", "MateDistanceDim"
                              Call CheckMateSelections(swMate)
                      End Select
                  Loop
              Sub CheckMateSelections(swMate As SldWorks.Mate2)
                  MateRefCnt = 0
                      ReDim swMateEnt(MateEntCnt)
                      For i = 0 To MateEntCnt - 1
                          Dim ref As Object
                      Next i
                          Debug.Print "  Missing mate selection: " & swSubFeat.Name ' Mate name which is having Missing Selection Reference
              Matt
