Can anyone please help me with the modelling process of a honeycomb sandwich panel. I want to model a honeycomb sandwich panel of thickness 18 mm (17mm core and .5mm of sheets on both sides) the facing is attached to the core using epoxy adhesive resin. Please Help. Its really urgent for my project. Thanks in advance !
This should be simple extrude after you create the honeycomb (there can be several ways to create the honeycomb) but you won't be able to replicate the effect of epoxy in SOLIDWORKS. I'm not sure about any other tool/software which can be used.
